Water pump gasket is leaking #940815 04/16/09 11:21 PM
ChrisB Offline OP
Was changing the oil today in my 01 and noticed some mud was wet.My waterpump gasket is leaking.Is there an easy way to change this.Whats the steps?
01 Kia sportage,Removed front bumper,Warn manual hubs,
Soon To Come.Cb,4"lift,31's,Custom front bumper,Rock sliders,Winch,Roof rack,Hitch
Make it Break it
Re: Water pump gasket is leaking [Re: ChrisB] #940816 04/16/09 11:52 PM
k120189 Offline
pretty much same as doing a timing belt..have someone help you. i got a new water pump in in about an hour. use some rtv as well
<a href="www.pittsfieldcustomsclub.com/sportage.html" target="_blank">98 sportage</a>: warn manual hubs,upyourkia spacers, 104 tj springs, 235/75/r15 BFG T/A KO, tracker rims, cone air filter, custom cat-back with a skunk2 muffler. gonna be a 2.3L
Re: Water pump gasket is leaking [Re: k120189] #940817 04/17/09 02:52 AM
ChrisB Offline OP
Ok it is bearly leaking so i should have some time before i have to do it.
Make it Break it
Re: Water pump gasket is leaking [Re: ChrisB] #940818 04/17/09 02:01 PM
k120189 Offline
how many miles on the engine and how new is the pump and timing belt? if they are over 60k miles each.. replace them both. if u replace just the belt it will finish the pump off and you'll have to go back and replace it anyway. take it from me
Re: Water pump gasket is leaking [Re: k120189] #940819 04/17/09 02:15 PM
6
69442 Offline
Not really sure that's the case, I'm on my forth belt at 249,580 miles and still the orig pump!! <img src="/forums/images/graemlins/nana.gif" alt="" /> I inspect it each time for leaks and it seems to be fine. Now, if cash isn't an issue for you then by all means replace it. Better off safe than sorry while your already in there. I'm basically a cheap bastard. I flush the coolant every other year and change the Eng oil every 2500 miles and can't seem to kill it. It also isn't burning any oil yet! So, maybe each rig is different or mine wasn't built on a Friday close to beer thirty!!
Most important is replacing that belt due to it being an interference motor. For those of you who don't know what that means, when the belt goes there is no longer anything to keep your pistons from B**** slapping your valve train!! Thus needing some serious engine repairs that would likely exceed LKQ assy replacement. So, change those belts before 60k for sure and pumps when needed. <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Water pump gasket is leaking [Re: 69442] #940820 04/17/09 02:31 PM
k120189 Offline
info is wrong. snapped a timing belt not an interference engine. mine had no issues .05% of people do. dont mean to sound rude.in class sneaking a response.
Re: Water pump gasket is leaking [Re: k120189] #940821 04/17/09 02:44 PM
6
69442 Offline
I'm a Insurance Appraiser and had a customer who claimed their engine failure as a result of a belt issue. I then had a regional Kia rep tell me they were "interference motors" and this was a maintenance issue not a claimable loss! He then described to me exactly what I stated earlier. So I will do some more research for my own knowledge and if I'm incorrect I will change my statement.
LIFT OR BUST! 2001 Sportage EX 4dr 4WD with 300,210 miles & counting .....
____o_o
l_l_l\___\___
l----[o]==[o]
l----==[--]==
()_)()_)--()_)
Re: Water pump gasket is leaking [Re: 69442] #940822 04/17/09 03:06 PM
k120189 Offline
ok. here is a good place to start. this is where i found out i still had a fighting chance at keeping my sportage alive when i snapped the belt. i have experience with this. i actualy replaced my belt in a tech school parking lot and it ran ,and up until a few days ago (unrelated issue), was running like a champ. its called and interference engine because there is a possibility of valve damage but it is more common that there is no damage done by the belt snapping. but trust me im not testing my luck with this one i dont want my kia to be that slim chance ya know?
Re: Water pump gasket is leaking [Re: k120189] #940823 04/17/09 04:06 PM
6
69442 Offline
Well, here's what I found out. I just got off the phone with a Master Tech at my local dealer. This guy supposedly builds turbos for this specific engine and knows it well! He said that the 95 Sportage was "considered" a true interference engine. 1996 - 2002 are not considered interference engines by Kia. He then said that even though they are not considered to be a interference engine they have still experienced valve dmg after belt failure! Even with his depth of personal experience with this engine he could not provide a solid answer as to why?? All I'm saying at this point is that Kia recommends the belt be replaced every 60k so why take the chance? <img src="/forums/images/graemlins/confused.gif" alt="" />
____o_o
l_l_l\___\___
l----[o]==[o]
l----==[--]==
()_)()_)--()_)
Re: Water pump gasket is leaking [Re: k120189] #940824 04/17/09 04:35 PM
A
Airdale73013 Offline
I have Factory Service Manuals and they state that the FE3 engine in the Sportage, both the SOHC and DOHC, are non-interference engines. This subject has been discussed many times on this forum.
2009 Sorento LX, 4x4, V6, Auto, Red
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.005s) Memory: 0.6427 MB (Peak: 0.7648 MB) Data Comp: Off Server Time: 2026-10-21 20:44:04 UTC
