Better brakes in GEN I??? #941046 04/18/09 03:54 AM
JorgeA Offline OP
Hello guys... I did my homework and tried to find with the search engine on the database about getting better break response on Gen I (82)without any luck.
Anyone knows how to improve brake system other than change calipers and disks on the Gen I models? maybe there is a swap master cylinder for newer models or also includes booster?.. Any ideas?
Thanks
JorgeA
Re: Better brakes in GEN I??? [Re: JorgeA] #941047 04/18/09 04:25 AM
CapnCrunch Offline
You have to swap calipers, caliper brackets, rotors, and (if you like) master cylinder/booster. You can either use Gen I V6 brakes or Gen II brakes.
I swapped calipers, caliper brackets, and disks from a Gen I V6 into my 88, but I didn't swap the master cylinder/booster. With 33x12.5 tires on it, it'll lock up the wheels on dry pavement (that's happened to me). It's also strong enough to blow a brake line if you brake hard enough (that's happened to me, too).
I'm not sure if the 82 has the same master cylinder/booster in it as the 88, though. I think mine might be a little stronger.
?_________
|_|_|\____\___
l-----[O]≡≡≡≡[O]
()_)()_)-----)_)
Stay the Trail!
Re: Better brakes in GEN I??? [Re: JorgeA] #941048 04/18/09 05:29 AM
Kevin C Offline
Searh my name "Kevin C" and +v6 +Brakes
Also I have a web page from a few years ago.
http://www.geocities.com/spun_bearing/brakes.html
Kevin
Re: Better brakes in GEN I??? [Re: Kevin C] #941049 04/20/09 03:15 AM
JorgeA Offline OP
My actual Iron master cylinder is 7/8 and I think the booster is one diaphragm while the 88 V6 models have 15/16 Master Cylinder with a double diaphragm booster. I think it will be a good idea to swap since I already bought a brand new 83 (small) disks and shoes for the front brakes.
Anyone has changed the master cylinder with booster already?
Thanks
JorgeA
Re: Better brakes in GEN I??? [Re: JorgeA] #941050 04/20/09 04:52 AM
KrzyDav Offline
I put front brakes off a 98 2wd Montero Sport on my 89 V6. They are the same calipers as on a Gen 2, but being off a 2wd they were in real good shape, no rust or mud.
dave h.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6082 MB (Peak: 0.6732 MB) Data Comp: Off Server Time: 2026-06-09 22:00:13 UTC
