1990 Trooper Homebuilt #941333 04/19/09 10:49 PM
barak Offline OP
Hi guys , it's official , I am selling my Trooper that I built.If anyone has been following my build over the years , you know how much work and parts went into this project , but I just don't have the time to finish it up like I wanted.For anyone that has air-care or emissions testing , this truck will NOT pass the tests , although I have been using it as a daily driver since I built it.It makes a hell of a 4x though for anyone that is looking for a good offroader and doesn't want to do a whole lot of work or put a lot of parts into it.The body is not the greatest , but I wasn't worried about that right away , although I did put new front fenders on it as they were rusted really bad when i got the body.
-4" suspension lift
-3" body lift
-1.5" seat lift
-3.4 engine with 1.6 roller rockers , 4.3 throttle body , bored out and coated intake , K&N air filter , under drive pulleys , MSD coil , MSD ignition box , 8 MM wires (Dyno Tested to over 220 HP with 33" tires)
-33" mud tires , 85% wear left
-tera gears in transfer case (Automatic)
-aisin hubs
-locker in front
-Rancho 9000 shocks and control box( box not installed)
-rear LSD
-all bushings in the front were replaced , new brakes , rotors , etc
-custom fuel system
-alarm system
-braided stainless hose for fuel lines and russell fittings
-remote oil filter(2 filters)
-headers
2 1/4" exhaust with flowmaster 50 muffler
-trailer hitch
-limo tinted windows , all except 2 front and windshield
-step bars
-fender flares
-33" spare tire
-bush bumper with 9000 pound winch and cover
-darlington 1.5" differential drop
-darlington licence plate holder for winch
-heavy duty torsion bars
-3 fuel filters (1 removes water)
-brake speedbleeders (russell or maroso can't remember which)
-fuel pressure guage (1 inside the cab 1 under the hood)
-battery isolator under the hood
-battery in the back for electric fan
-electric fan and fan controller
-Independant 4x heavy duty Tie Rods
-front fenders replaced with brand new ones
-traction bars so the rear wheels wouldn't hop on take off
Thats all I can think of off hand for whats been done to the truck and on the truck , if I think of anything else , will post it.Here is a list of what I have for spare parts
-universal joint
-original 2.8 engine
-spare auto tranny and extra belhousing
-kit to fill air conditioning
-fiberglass hood scoop (covers most of the hood)
-everything you need to add power windows and power locks
-spare MSD coil
-digital fuel guage that will fit in the normal area( have a large one for now , was going to replace the oil and temp guages in the cluster with matching ones but never got the other 2)
-all kinds of misc parts like extra doors , lights , etc.
I will have to look and see what else I have laying around for extra parts that never got put where they were supposed to go.
There are a couple of issues that I never had time to fix , but they aren't major and don't affect the trucks drivability at all.
1- there is a small leak in the transmission fluid lines somewhere , I am guessing most likely on the cooler I had installed as once a month the tranny will go into limp mode , so you just add a little fluid and your good to go again.
2- there is also an issue with the brake fluid leaking from somewhere as again , once a month the fluid is down and needs to have some readded.Again I am thinking this is an easy fix , just a matter of finding where it is going.
3- last time I went 4xing in it , I hit a stump with the corner of where the bush bumper is welded to the frame and it cracked it , that needs to be re welded and maybe some ectra support.Right now I have a piece of angle iron on there to hold it on so it doesn't come loose and rip off the bumper and winch , again an easy fix.
4- There is an occasional clunk from the front , and I am pretty sure its the common problem that the aisin hubs have with the little allen bolts coming loose , or maybe even the clip , again an easy fix.
Thats pretty much it , the truck starts fine , runs strong , and has lots of power and is pretty much unstoppable <img src="/forums/images/graemlins/smile.gif" alt="" />
I do have a piece of steel that was going to be used to fix under the driver side doors as that is rusting , and the rest of the body work can easily be done also.Here are a couple pictures I took of the truck , not sure if it shows , but there are dents on the rear doors at the top , that was done while the truck was being lifted to put on the frame , the straps tightened a little too much with the weight of the truck.
[img][image]http://i2.photobucket.com/albums/y26/shadowbarak/IMG_2329.jpg[/img][/image]
[img][image]http://i2.photobucket.com/albums/y26/shadowbarak/IMG_2332.jpg[/img][/image]
[img][image]http://i2.photobucket.com/albums/y26/shadowbarak/IMG_2335.jpg[/img][/image]
[img][image]http://i2.photobucket.com/albums/y26/shadowbarak/IMG_2331.jpg[/img][/image]
[img][image]http://i2.photobucket.com/albums/y26/shadowbarak/IMG_2330.jpg[/img][/image]
Now for the price , I am asking 2700 , and I think that is very reasonable considering all the parts that are in this truck.even if you found a very cheap trooper and wanted to build it up like this , you would be putting out at least 5000+ to get all the parts and stuff.This is a 1 of a kind truck as it has a custom starter setup to fit the headers , complete custom fuel system with a 19 gallon fuel cell , and a few of the other things that were done during the build up.
As for location , its in my signature.I would not hesitate for a second to take this truck on a long trip as it sits right now , as I have driven it across western canada right after I built it with no testing <img src="/forums/images/graemlins/lol.gif" alt="" /> All you need is to take some fluids with you and keep an eye on the levels.
I hate to part with this truck as I put a lot of work into it , but with no time to do anything to it , I had to go get something I can use as a daily driver and not have to worry about upkeep and stuff.I will still be on the forums though as I bought a Jeep <img src="/forums/images/graemlins/ignore.gif" alt="" />
Re: 1990 Trooper Homebuilt [Re: barak] #941334 04/28/09 02:04 AM
barak Offline OP
bump
Someone must be looking for a trail ready rig that has pretty much everything you need allready installed on it.
Re: 1990 Trooper Homebuilt [Re: barak] #941335 05/18/09 10:30 PM
barak Offline OP
well , doesn't look like any interest in this very capable truck , so I am now going to list it local.I was hoping it would go to a good home and someone that would look after it the way it should be , but it will probably end up going to some young kid that will kill it within a few months , and just scrap it , even with all the parts that went into this.
Re: 1990 Trooper Homebuilt [Re: barak] #941336 05/20/09 03:49 AM
kewlynx Offline
Did you post it on bc4x4?
**ubi apis- ibi salus**
Re: 1990 Trooper Homebuilt [Re: kewlynx] #941337 05/20/09 04:38 AM
barak Offline OP
I posted it on the local craigslist , not sure what else to post it on out here.
Re: 1990 Trooper Homebuilt [Re: barak] #941338 05/20/09 04:58 AM
kewlynx Offline
www.bc4x4.com <img src="/forums/images/graemlins/pfft.gif" alt="" />
You didn't know about this site?
Re: 1990 Trooper Homebuilt [Re: kewlynx] #941339 05/20/09 04:59 AM
barak Offline OP
Nope, didn't know about that site at all. With work I am not home a lot , and don't get to spend a lot of time doing too much:P
I will post there right away.
Re: 1990 Trooper Homebuilt [Re: barak] #941340 05/23/09 08:26 PM
P
prong Offline
Just curious, you dynoed 220hp at the wheels? Without the nitrous you were planning on adding etc?
Re: 1990 Trooper Homebuilt [Re: prong] #941341 05/24/09 12:31 AM
barak Offline OP
yup , it was at 107 MPH and still climbing when the tranny kicked into overdrive and it flatlined.Because it wouldn't stay in 3rd without the OD kicking in , we couldnt get exact numbers at where it would have stopped.
Re: 1990 Trooper Homebuilt [Re: barak] #941342 05/27/09 12:05 AM
P
prong Offline
Thats cool, I had read stuff about how it was torquey but hard to get much over 200 at the crank with bolt on stuff. My wet dream is to take an isuzu 3.2 and put it in my 1G troop and turbo it or something (make it 100% isuzu). Sorry to create traffic on your thread unrelated to sale - I would buy it in a heartbeat if I was in canada and didnt just lose my job! I'm going to have to pull off some neat tricks just to get my trooper driving again!
Moderated by  4x4Wire, code33, kewlynx
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6488 MB (Peak: 0.7752 MB) Data Comp: Off Server Time: 2026-06-20 18:16:41 UTC
