Re: NP435 to Dana 300 [Re: BobRowe] #941598 04/24/09 01:55 AM
DBL_DTY97TJ Offline
I missed that part of the post. Yes, absolutely do that.
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: NP435 to Dana 300 [Re: DBL_DTY97TJ] #941599 04/24/09 04:54 AM
Bigbird79 Offline
Yeah I missed it too, do that in a heart beat. Kudos to Novak for offering to take care of the issue! That's great.
99 XJ Sport 2 Door, 4.0L, 5 speed, all stock. Daily Driver
79 F150 Standard Cab Short Box, 400ci, NP435, NP205, 35" SSRs
Re: NP435 to Dana 300 [Re: BobRowe] #941600 04/26/09 02:52 AM
superdawg Offline
Before doing anything rash, call someone that does these conversions everyday using, Advance Kits, and Novak.
Mitch at RMH transmissions knows AA and Novak and these tranies. 303-808-1268
I had that combo in my 73 CJ5 304,NP435 and D300 I don't recall any hickups with the AA kit.
SD
Re: NP435 to Dana 300 [Re: superdawg] #941601 04/28/09 11:20 PM
JeeperDan Offline OP
Yeah, I'm definitely impressed with how Novak handled the situation. They also said that I should be fine running it with five bolts and that they'd warranty it that way, but I'm more concerned about my tranny and T-case, which have no such warranty.
As far as rotating it goes, I rotated and flipped the gasket every which way before determining that 5 bolts was the best I was going to do. Also, there is a transmission mount built in to the adapter, so it is pretty clear which way it is supposed to be mounted.
I agree that having Novak cut one custom is the best solution, and that is why I was hoping someone would know exactly where this bolt pattern came from. I guess I will just have to dimension the 6th hole and hope that it lines up perfect. I'll also give Mitch at RMH a call and see what he knows about it. I'll post when I know how it's all going to shake out.
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.006s) Memory: 0.6070 MB (Peak: 0.6785 MB) Data Comp: Off Server Time: 2026-10-22 07:40:36 UTC
