Fill/Drain front dif
#941628
04/21/09 02:55 AM
I was looking at my front dif and cant figure out how to fill or drain it.Can someone help me out.
01 Kia sportage,Removed front bumper,Warn manual hubs,
Soon To Come.Cb,4"lift,31's,Custom front bumper,Rock sliders,Winch,Roof rack,Hitch
Make it Break it
Re: Fill/Drain front dif
[Re: ChrisB]
#941629
04/22/09 02:19 AM
Make it Break it
[Re: ChrisB]
#941630
04/22/09 03:39 AM
Can't remember 100% for sure, but there should be a fill plug on the backside of the diff, fill until comes out the hoke. As for draining! Crack the bolts, let it flow! BTW! your going to need a new seal!
08' Jeep Wrangler 64' Plymouth Sport Fury 383 58' Triumph TR-3A
[Re: ChrisB]
#941631
04/22/09 05:02 AM
There is a drain plug on the bottom of the dif, in the front facing fowward. The fill is on I believe the right side of the dif about 1/2 way up.
Hope tht helps, Dennis
95 Sportage, gone but not forgotten. 98 Jeep TJ, 4" Zone springs with RC Long arms, Ford 8.8", 4.56 gears & Detroit locker rear, D30, 4.56 & Detroit Trutrack front.
[Re: ChrisB]
#941632
04/22/09 06:09 AM
to fill buy a gear oil pump it should screw into the bottle of gear oil just put the the tube into the filler hole and pump away.
2001 5sp. K&N stock filter 215/70/15 If your check engine light is on at least you know the light still works
[Re: bombardj1]
#941633
04/22/09 02:38 PM
i didnt see a fill or drain plug when i was under it
Make it Break it
[Re: ChrisB]
#941634
04/22/09 06:05 PM
both the fill and drain plugs are on the side of the halfshaft, the drain plug is not on the bottom of the diff. both are facing the front of the truck, look for them, the sway bar and other steering stuff could be in the way so you don't see them, thats why to fill you need a pump. remove the spash gaurd you should be able to see them and get to them.
[Re: ChrisB]
#941635
04/22/09 06:20 PM
did you try the kiatechinfo site to show you ? if not, sign up for it it's free it will help show the both plugs.
