Got propane?
#941830
04/21/09 09:17 PM
Just called Gotpropane.com He wanted me to send carb gasket so he can see if he has one that would work. I was wondering if some one could actually trace on a piece of paper the gasket and scan and email me it? Its on the 89 Raider 2.6 The Email is smrover1@aol.com
89 Raider 2.6 with 32x9.50 Tsl Bias on stock rims turned inside out. Yota shackles in rear front T bars cranked no sway bar,ditched reed valve and capped with quarter
Re: Got propane?
[Re: GUNIT]
#941831
04/21/09 09:42 PM
I live near their shop i could just dorp off a manifold.
Re: Got propane?
[Re: TOASTY]
#941832
04/21/09 09:46 PM
That would be great if you could. I just called them just a couple hours ago. I really would love to finally climb hills without spitting and sputtering
Re: Got propane?
[Re: GUNIT]
#941833
04/21/09 10:20 PM
How about a Starion EFI setup?
Salvage yards parts and no carb.
Kevin
Re: Got propane?
[Re: Kevin C]
#941834
04/21/09 10:51 PM
The starion swap is good I just think the propane swap would suit me better. My Raider is pretty much offroad use only. I think I would rather run on propane than gas. Plus I would hate to run to junkyards trying to find good parts. hopefully toasty can drop off manifold if not I will buy gasket and send to got propane.
Re: Got propane?
[Re: GUNIT]
#941835
04/22/09 01:30 PM
Re: Got propane?
[Re: raiderquest]
#941836
04/22/09 03:55 PM
What manifold are you running there are like 3 different types on the 2.6, It might not matter since they'll probably use the weber adapter anyways. the manifold i have has the EGR stuff.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6140 MB (Peak: 0.6917 MB) Data Comp: Off Server Time: 2026-06-22 14:17:27 UTCValid HTML 5 and Valid CSS
