aftermarket fuel gauge for trooper #941972 04/23/09 01:32 AM
carlw Offline OP
i have a 1989 trooper ,,,i have a 350 chevy engine in it, i took out the 3 gauges that are in the middle of the dash on the factory gauge cluster,and put my temp and oil presure gauges in there and i need a aftermarket fuel gauge that will work with the factory sender,at least work good enough to tell me i am about to be walking.
how would i go about getting the rite gauge? has anyone of you done this in a hot rod trooper?
or do any of you know the ohms of the isuzu tank sender?
Re: aftermarket fuel gauge for trooper [Re: carlw] #941973 04/23/09 03:16 AM
Madcat Offline
I swapped out my gauges for Auto Meter units.
The factory ohms don't match anythingout there so i got the matching sender/gauge combo.
Jim
1979 Pontiac Trans-Am - looking 4 a pontiac 455cid
1988 Trooper II - AMC head, .030 overbore, Calmini cam. Toga HV oil pump, Aisins, soon 2 b turbo
1989 Impulse Turbo - Fidanza flywheel, 270cc injectors, turbo-back exhaust, KYBs F/R
Re: aftermarket fuel gauge for trooper [Re: carlw] #941974 04/23/09 03:21 AM
maxwell417 Offline
From The Isuzu Achives smile
this info is from Stewart Warner:
Ohms/Resistance
(Empty/Full) Popular Models
0 - 90 Ohms GM cars, 1965 to present
0 - 30 GM cars prior to 1965
73 - 10 Fords prior to 1989 & most Chryslers
16 - 158 Ford post 1987
240 - 33.5 often seen as US or SW standard
120 - 17 Isuzu Trooper
What I would have done is screwed the Isuzu senders into your 350. Probably to late for that now <img src="/forums/images/graemlins/pfft.gif" alt="" />
Curt B 89RS Calmini Header Delta Cam 33x10.5 BFG MTs & 90 Trooper 3.4 v6, SAS D44 ARB/Hobart 5.38s 35s my pictures
Re: aftermarket fuel gauge for trooper [Re: maxwell417] #941975 04/23/09 03:31 AM
carlw Offline OP
yea way to late ,i thought about it but the scrap guy got it by then.
thanks for the help dudes.
i been googling for it and it seems allot of people like to take the trooper fuel tank and bolt them inbetween the frame rails in front of the rear bumpers under there pickup trucks.anyway im going to look for a digital adjustablt gauge,and if i dont like what i find i will adapt a marine sender to the isuzus sender plate, a teleflex gauge and sender is only 50 bucks or so,
if any of yall know of adjustable fuel gauges i would love to hear it.
edit----------------------------------------------------
never mind i found exactly what i need a universal adjustable gauge.SWEEEEEEET!
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6016 MB (Peak: 0.6584 MB) Data Comp: Off Server Time: 2026-06-21 12:18:02 UTC
