ROUGH IDLE? #942225 04/25/09 04:27 PM
RALFIRECAPT Offline OP
I have a 84 CJ7. It has been converted to a 304v8. It normally runs smooth. However on random occassion it will start running rough, idle will drop and will cut off if I don't keep my foot on the accellerator. I will continue to run like this until I park it. The next time I run it, it will run perfect. It may go 50 miles or a couple of hundred befroe it does it again. Any ideas?
Re: ROUGH IDLE? [Re: RALFIRECAPT] #942226 04/25/09 04:50 PM
BigJim Offline
Golly Tarheel! It could be any number of things... You need to narrow it down to either lectric or fuel. Does it smoke when it deceides to go bad on you? If black smoke when it is stumbeling then the carb may be going south.. If it refuses to gain rpm it could be lectric.
First thing is to check the plugs and wires to make sure it isn't just in need of a tune.
Re: ROUGH IDLE? [Re: BigJim] #942227 04/25/09 09:56 PM
4x4Wire Offline
I have had a similar issue with 304 in a 74 CJ5.
Turned out to be a cracked distributor cap.
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5919 MB (Peak: 0.6452 MB) Data Comp: Off Server Time: 2026-06-21 13:41:14 UTC
