headlights - high beams not always working #942752 04/29/09 05:10 PM
TomPoh Offline OP
my high beams are not working when i push the turn signal lever forward, but do work when i pull the level back. if i switch back and forth 10+ times, the high beams occasionally come on. low beams are working fine.
do you think this is a problem with the turn signal lever? contacts...any way to clean or add snake-oil?
Tom
95 T100
95 T100 SR5 Xcab 4X4
Re: headlights - high beams not always working [Re: TomPoh] #942753 04/29/09 08:10 PM
BamZipPow Offline
It's the switch alright. It will take some effort to git to it and you can clean it out with some contact cleaner. Had to do this fer a friend's T-100. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: headlights - high beams not always working [Re: BamZipPow] #942754 05/01/09 12:31 PM
TomPoh Offline OP
thanks for the info.
Re: headlights - high beams not always working [Re: TomPoh] #942755 05/01/09 04:13 PM
BamZipPow Offline
Looking up the part on ToyoDIY.com
and cross referencing the price on ToyotaPartSales.com...
8414035100 $53.67 $0.00 $40.34
Electrical - Chassis electrical - Switches - Headlamp dimmer switch
Headlamp dimmer switch, t100 1995 - 1998
So probably about $53 or so shipped.
If you go this route, you'll have to be careful when you remove the pins from the connector and making sure you keep the same wires in the same spots. <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: headlights - high beams not always working [Re: TomPoh] #942756 05/01/09 04:17 PM
garym Offline
If you want ot go the cheap route they still sell the old foot switches at most parts stores. You could rewire that circuit to one of those.
1997 T-100 4X4 Xcab,Warn Hubs
02 Camry LE
2008 Yaris
Re: headlights - high beams not always working [Re: BamZipPow] #942757 05/04/09 12:09 PM
TomPoh Offline OP
thanks. great info. i'll probably buy the part.
tom
Re: headlights - high beams not always working [Re: TomPoh] #942758 05/11/09 12:15 PM
TomPoh Offline OP
2-3 hour job, just a PITA to pull out the headlight dimmer part. have to strip down everything to remove the entire combo switch/spiral cable assembly. once out, the swap is a breeze.
tom
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6163 MB (Peak: 0.6902 MB) Data Comp: Off Server Time: 2026-07-09 21:14:34 UTC
