Coolant & AC radiators #944195 05/07/09 11:03 AM
fokion Offline OP
lets see......
in our car, contrary to efficiency, the engine one is BEHIND the AC one, obviousty because we have the engine-belt driven fan for cooling..
But NOT all of us. <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
in the case that an elektrik fan is installed how much sence it makes you to reverse the order of the radiators and have ( by swapping places or just mounting behind )the engine one in front for better cooling??
Re: Coolant & AC radiators [Re: fokion] #944196 05/07/09 05:41 PM
Everet Offline
Your AC will not be as cold. It probably could be done but why?
Are you overheating?
If so, maybe your radiator is old...
What I did was remove the AC electric fan and put a 16" pusher on the AC condenser and a puller on the back side of the radiator.
Works great!!
You should also check your thermostat if you are having overheating problems.
Easiest way is in a pan of water on the stove with a candy thermometer. Check the temp of the water as it rises. You should see the thermostat start to open at around 180f or so.
Just my 2 cents...
Re: Coolant & AC radiators [Re: Everet] #944197 05/07/09 05:55 PM
fokion Offline OP
( For argument shake.... )
No I am not overheating at least not mechanicaly..
my basic problem is..... mud
and thow I love splashing around washing the radiator is a pita..... since its behind the ac one and with the sroud in place its not easy to clean it from behind..
Now concerning the AC I am looking to my other car that the AC behind and doesnt have efficiency issues...
Dont forget I have an electric fan for the engine...
( as I said for argument shake...)
Re: Coolant & AC radiators [Re: fokion] #944198 05/07/09 08:42 PM
Everet Offline
...just for arguments sake...
On the AC--The other car you looked at was probably designed to be that way. The Sportage was designed for the condenser to be in front therefore it may not be as cold as before...
If it is easier for you, then go for it...
Let us know what the outcome is! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Good Luck,
Everet <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Coolant & AC radiators [Re: Everet] #944199 05/08/09 02:23 AM
londart Offline
since you have an elec fan, why not remove the shroud????wouldnt that make the whole scenario easier????
Lonnie
Auto Parts Professional
95 sportage sold but not forgotten
Re: Coolant & AC radiators [Re: londart] #944200 05/08/09 06:16 AM
fokion Offline OP
Everet... yes- hypotheicaly - the system is designed this way for the AC opperation.. Hmmm thats a consideration...
londart - in theory the sroud helps fun to suck air fron the complete radiator and not the part that is right infront of it
other than that its a nice place to mount the fan
I consider passing through the core mounting skrews VERY dangerous in offroad use, since tha vibrations might damage the rad.
Re: Coolant & AC radiators [Re: fokion] #944201 05/13/09 10:24 AM
Nukeiridium Offline
I would not remove the shroud, it contributes significantly to the efficiency of your radiator fan.
2002 Sportage 4dr 4x4 soon to undergo an Extreme Makeover!
Re: Coolant & AC radiators [Re: Nukeiridium] #944202 05/13/09 06:11 PM
fokion Offline OP
Nuke Garry Axeman................
What is your opinion?????
O am trying to gather as many opinions as possible...
Re: Coolant & AC radiators [Re: fokion] #944203 05/14/09 03:20 PM
k120189 Offline
placing the radiator in front of the ac would one leave your fan less efficient on the actual radiator and make your a\c warmer because it will be getting the warm air from the radiator
the fan would be less efficient because instead of the fan pulling air over the whole radiator and having the shroud direct it it would rely on whats left of the pulling force after the ac radiator...i hope this makes sense.
if you wanted the rad in front.. in theory you would almost have to run a pusher fan on the front.
<a href="www.pittsfieldcustomsclub.com/sportage.html" target="_blank">98 sportage</a>: warn manual hubs,upyourkia spacers, 104 tj springs, 235/75/r15 BFG T/A KO, tracker rims, cone air filter, custom cat-back with a skunk2 muffler. gonna be a 2.3L
Re: Coolant & AC radiators [Re: k120189] #944204 05/14/09 05:45 PM
fokion Offline OP
Hm... interesting....
But look how many cars have it this way
( But yes you have a good point there )
On the other hand if the engine radiator is in front it is cooled muuuuuuuuch more effectively so the fan will not be needed so much...
and yes possibly - probably I would say the ac efficiency will drop...
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6421 MB (Peak: 0.7667 MB) Data Comp: Off Server Time: 2026-05-29 19:55:11 UTC
