Hot Alternator #944699 05/11/09 06:02 AM
G
gerry_p Offline OP
I have a Buick V6 in my jeep. I've had starting problems lately - acts like not enough juice in the battery. Tonight I put my hand on the alternator four hours after I shut off the engine. It was hot but the engine was cool. I disconnected the battery. The alternator cooled off. Then I connected the battery again and an hour later the alternator was hot again. What's up with the alternator?
Gerry
Re: Hot Alternator [Re: gerry_p] #944700 05/11/09 06:36 AM
4x4Wire Offline
Replacement time.....
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: Hot Alternator [Re: gerry_p] #944701 05/11/09 01:11 PM
BobRowe Offline
It could be the alternator, but it could also be that the battery has a shorted or partially-shorted cell, demanding too much curent from the alternator. Take it to anyplace that sells batteries, and they should be able to twll which it is in no time.
Re: Hot Alternator [Re: BobRowe] #944702 05/11/09 03:50 PM
G
gerry_p Offline OP
Bob,
When I reconnected the battery, the alternator heated up without running the engine or even turning the key on. Couldn't it be a wiring problem and the alternator and battery are both OK?
Gerry
Re: Hot Alternator [Re: gerry_p] #944703 05/11/09 04:32 PM
BigJim Offline
Gerry your first comment was that the vehicle was getting harder to start...that in itself should tell you something.
As for the wires...have you been messing with them?
The first thing I would do is to put a voltmeter on the battery when it had been sitting over night.. I'd make sure it had 12+ Volts. If it did then I'd know it was still good.
Then I'd start her up and check the volts at idle to see if the alternator was putting out 14+ Volts.. Most likely you will find one or the other that isn't quite up to snuff.
Re: Hot Alternator [Re: gerry_p] #944704 05/12/09 07:43 AM
BobRowe Offline
Bob,
Gerry
Now thqt sounds like a bad alternator. If it's doing that, then the battery is forcing current through the alternator when the ignition is shut off, and the only way it can do that is if at least one of the diodes in the alternator has shorted out.
Re: Hot Alternator [Re: BobRowe] #944705 05/21/09 12:18 AM
G
gerry_p Offline OP
Yep, a bad alternator all right. I took it to a shop and they said the diodes were gone so they rebuilt it and it runs good now. By the way, this alternator is a delco "single wire" with an insulated post on the back and a two wire harness on the side. The guys at the shop plugged the harness hole with silicone and said to just tape off the harness and put the 12 volt wire to the post and call it day. I did and it works good. So why did they build it with unnecessary wires? Shop guy was out when I picked it up. Thanks for the help guys.
Gerry
Re: Hot Alternator [Re: gerry_p] #944706 05/21/09 01:10 AM
4x4Wire Offline
The same alternator probably has another application which would need a direct feed off the alternator.
John Stewart
Editor - 4x4Voice
PHP: 7.4.33 Page Time: 0.027s Queries: 15 (0.021s) Memory: 0.6229 MB (Peak: 0.7212 MB) Data Comp: Off Server Time: 2026-11-04 20:00:00 UTC
