GDI 3.5 idling at 1500rpm-help #944874 05/12/09 07:26 AM
Maki Offline OP
it all started when the truck almost stumbles at idle, i figured the throttle body is gummed up so i sprayed half a can of carb cleaner into the tb while trying to keep the revs at 3k rpms,making sure the carb cleaner doesnt get into the small inlets south of the tb. i reconnected everything up and now it idles at 1500rpms, i tried the ecu reset and ecu idle releard procedure but it still gets to 1500rpm the next time i start her up.
i have alredy removed the whole tb thinking that i might have moved some gunk into the inlets, cleaned it out even the isc, checked for continuity all is ok. connected everything back, still at 1500rpms.
when i remove the connector to the MAF though, the idles drops to a steady 1000rpms, and stays there even if i turn on the a/c. but when i reconnect the amf it shoots up to 1500rpms. theres no ECM or MIL light if the maf is connected.
as i understand from the workshop manual, the idle is controllled by the electronic throttle servo together with the isc, it looks at figures from the a/c load switch and the engine temp sensor and then compares it to a MAP or table with predetermined values. so i know the throttle servo is working because this also looks at the pedal when in drive and adjust the throttle plate to how deep i press the pedal. now im guessing it might be the engine coolant temp sensor or maybe the MAF?
if i disconnect the maf then everything almost idles fine ~1000rpms (normal around 750)
how do i check if the maf is defective if i dont have a known good one to swap it with. and btw upon inspecting the throttle plate, it has a gap between the throttle body, around less than a mm, is this normal or should it be fully shut?
Re: GDI 3.5 idling at 1500rpm-help [Re: Maki] #944875 05/13/09 06:19 AM
mxmikie Offline
change the o-ring on the biss screw
Re: GDI 3.5 idling at 1500rpm-help [Re: mxmikie] #944876 05/13/09 06:08 PM
Maki Offline OP
there is no biss screw on these units... no fiav, the throttle is servo controlled not directly linked via steel braided cable to the accel pedal like the v6 3.0...
i have cleaned the egr and the srvo that controls it, re adjusted tps still the same prob =(
Re: GDI 3.5 idling at 1500rpm-help [Re: Maki] #944877 05/13/09 06:37 PM
hazy_daze Offline
We didn't get these motors here in the States. So most suggestions from the US folks will be shots in the dark.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6017 MB (Peak: 0.6583 MB) Data Comp: Off Server Time: 2026-06-17 11:32:50 UTC
