Radiator upgrade #945336 05/13/09 06:35 PM
Ralph Offline OP
I have a 1991 Toyota 4x4 pickup with a 5 speed.
I need a radiator with more cooling capacity.
I've read that the aluminum radiators are better than the brass ones, A 1-row aluminum equals a 3-row brass.
Is this true?
Why wont a 6-cylinder radiator work?
Is there a reasonably priced unit for my truck?
Thanks
Ralph
Ralph
1991 Toyota 4x4 Standard Cab Pickup.
engnbldr cam and head.
Doug Thorley Headers
Home Made Cat Backs
30x9.5x15 BF Goodrich All-Terrain M/T KM2
Re: Radiator upgrade [Re: Ralph] #945337 05/13/09 07:40 PM
RatLabGuy Offline
I *think* the 6cyl (3.0)uses the same radiator as 2.4l.
Radaitors.com (or is it Radiatorbarn) has a 3-row aluminum one as a pretty good price, and will getit to you very fast.
Question Reality.
Re: Radiator upgrade [Re: Ralph] #945338 05/13/09 09:41 PM
OOP'S Offline
The biggest problem with an aluminum radiators is fixing them on the trail.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Radiator upgrade [Re: OOP'S] #945339 05/14/09 12:57 AM
CJM Offline
yep 3.0 will work .. with very "minor" modifications (fan shroud) .. also a 2.4L turbo rad will "bolt in" and work great .. it's a 3 core .
83 Trekker SR5
NEW Trekker forum
Re: Radiator upgrade [Re: Ralph] #945340 05/16/09 08:07 AM
Davepet Offline
Is this true?
Depends on who you believe. Seems the way the radiator is constructed has more effect than the material used. Here's one take on the subject, but you can easily find others saying different:
http://www.usradiator.com/testing.htm
Dave
Re: Radiator upgrade [Re: RatLabGuy] #945341 05/16/09 10:25 AM
Snowtoy Offline
The 3.0 radiator is bigger, but mounts the same.
Re: Radiator upgrade [Re: Snowtoy] #945342 05/30/09 03:45 AM
Ralph Offline OP
The winner was radiatorbarn.com .
$189.92 for a all metal 3 row radiator delivered.
Thanks for the input.
Ralph
Re: Radiator upgrade [Re: Ralph] #945343 06/06/09 08:35 AM
Ralph Offline OP
Put in the 3 core radiator.
Nice and quick fix.
Ran it hard this afternoon and it didn't even care.
I was surprised on how much more coolant the radiator held.
Ralph
Home Made Cat Backs
Re: Radiator upgrade [Re: Ralph] #945344 06/09/09 03:15 AM
carter Offline
Ralph
radiatorbarn.com is good!
Mike Carter
85 & 86 4Runners
My Website
Re: Radiator upgrade [Re: carter] #945345 06/22/09 08:42 PM
suba Offline
One thing to keep in mind is the fan shroud. The shroud will make a big difference in cooling at low speeds due to more effective airflow through the radiator. Without it you have less consistent/even flow and wasted fan energy.
86 4runner, pro comp AAL, Kayline Soft top, 31's but all stock
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6404 MB (Peak: 0.7598 MB) Data Comp: Off Server Time: 2026-06-21 12:22:07 UTC
