Re: Gen 3 REAR BUMPER Build **Pics** [Re: icysyrup] #945395 05/29/09 02:44 PM
G
Guntero Offline
The bumper looks really clean. Good work.
Are there any places on the bumper that can facilitate the use of a Hi-Lift Jack? Maybe the step on the side?
Guntero (died in battle)
1995 Montero LS - Matte Black
265/75R16 BFG All-Terrains
Guntero (current)
2001 Montero Limited - Gold
OME HD Lift
285/75R16 BFG All-Terrains
Re: Gen 3 REAR BUMPER Build **Pics** [Re: Guntero] #945396 06/01/09 09:36 PM
icysyrup Offline OP
Thanks Hooch, I have not tested the side step yet. It is built out of 1/8" so should be plenty stout enough. The bumper on the rear could also be used to lift with the highlift on either side of the hitch. Once I have finish welded everything up I will test it and report back. <img src="/forums/images/graemlins/smile.gif" alt="" />
Phil
03 Montero XLS, OME 2"suspension lift,Full skid plates, Extended Diff/transfer breathers. 34 LTB's, Winch w/syn rope, Locked front/rear.
Re: Gen 3 REAR BUMPER Build **Pics** [Re: icysyrup] #945397 06/15/09 09:35 PM
icysyrup Offline OP
Anyone interested in these...post up. PM me for more details if needed.
Re: Gen 3 REAR BUMPER Build **Pics** [Re: icysyrup] #945398 06/15/09 10:39 PM
fastlayne Offline
Nice job man! how thick of steel did you use on that and did you just brake it all or cut and weld each panel? either way it looks great, almost factory
Where da mud at?
Re: Gen 3 REAR BUMPER Build **Pics** [Re: fastlayne] #945399 07/13/09 05:27 PM
icysyrup Offline OP
Finally got time this week while I was off work to finish this bumper up. In these other pics it is just tack welded together, has a quick coat of paint on it to stop the rust, and it doesnt match the Monty at all. So I got all those things fixed. Its now completely welded up, actually matches mine and is mounted up and good to go.
Re: Gen 3 REAR BUMPER Build **Pics** [Re: fastlayne] #945400 07/13/09 06:40 PM
icysyrup Offline OP
Its made out of 1/8" steel plate. The square tubing that was the foundation had 45 degree notches put in it so that we could bend it around and still get the nice radius bend under the tail lights. The panels ont he bottom are cut and welded and the one directly under the tail light is done with a break to get the nice round radius. The main mounts are 1/4" where the hitch reciever is and it mounts to the tow hitch points. Hope this helps
Phil
Re: Gen 3 REAR BUMPER Build **Pics** [Re: icysyrup] #945401 07/13/09 07:32 PM
Mad_Scientist Offline
Looks awesome <img src="/forums/images/graemlins/kewl.gif" alt="" /> I needed one of those on Saturday <img src="/forums/images/graemlins/scared.gif" alt="" /> (see URE thread)
Re: Gen 3 REAR BUMPER Build **Pics** [Re: icysyrup] #945402 07/15/09 03:43 PM
Angelo Offline
That looks good man! Good ideas you got there. Wish we were neighbors, so we could also wheel too <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6335 MB (Peak: 0.7454 MB) Data Comp: Off Server Time: 2026-06-10 01:49:15 UTC
