Page 2 of 3 1 2 3
Re: What I Did Instead of Going to Moab [Re: Jim_Paget] #945769 05/19/09 04:58 PM
BigSwede Offline
Bummer Jim! We missed you...there were actually 3 other 1st gen Troopers there this year!
Serenity now!
Re: What I Did Instead of Going to Moab [Re: BigSwede] #945770 05/19/09 08:36 PM
Storm Trooper Offline
Pictures from the fun (mostly) at Walker Valley
Walker Valley
'91 Trooper
3.4 V6, K&N, 33x12.5 Trxus MT's, Aisin hubs, 3" body lift, Rear ARB Naches Trail
Re: What I Did Instead of Going to Moab [Re: Storm Trooper] #945771 05/23/09 11:06 PM
Jim_Paget Offline OP
Well, I just found out what happened in the t-case. The needle bearing went south, in a big way. Since the hi-low slides on that bearing, it is pretty obvious why I could not get into 4-lo.
The clutch was really toasted, also. It was gone to the point that the pressure plat wasn't holding it against the flywheel. It was just sort of floating around in there.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: What I Did Instead of Going to Moab [Re: Jim_Paget] #945772 05/24/09 12:13 AM
mlclark Offline
Isuzu Moderator
Did you loose the ball bearing?
m
Re: What I Did Instead of Going to Moab [Re: mlclark] #945773 05/24/09 01:07 AM
I haven't torn it down that far yet to find out.
Jim Paget
www.rrr4x4.com
Re: What I Did Instead of Going to Moab [Re: Jim_Paget] #945774 05/24/09 04:09 AM
mlclark Offline
Isuzu Moderator
What about the previous install-uninstall merry-go-round game you played? Did it make it back in where it was supposed to go? Or, you probably were not pulling the hi/lo cluster during those times.
Tis a bummer, though. I hope the mainshaft is ok. Does the cluster spin or is it welded to the shaft?
Michael
Re: What I Did Instead of Going to Moab [Re: mlclark] #945775 05/24/09 04:46 AM
We'll find out tomorrow.
Jim Paget
www.rrr4x4.com
Re: What I Did Instead of Going to Moab [Re: Jim_Paget] #945776 05/24/09 06:00 AM
mlclark Offline
Isuzu Moderator
Oh, the suspense is killing me...
Re: What I Did Instead of Going to Moab [Re: mlclark] #945777 05/25/09 01:34 AM
Well, the good news is that the needle bearing isn't welded in place. All the needles are in the bottom (since it is standing on the bellhousing) of the case. Things rattle around just fine. That is good news, I guess.
Jim Paget
www.rrr4x4.com
Re: What I Did Instead of Going to Moab [Re: Jim_Paget] #945778 05/27/09 11:20 PM
mlclark Offline
Isuzu Moderator
*tap*...*tap*...*tap*...
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6375 MB (Peak: 0.7452 MB) Data Comp: Off Server Time: 2026-07-13 18:50:48 UTC
