swaping 86 22r 2wd into 84 4x4, does the oil pan need to changed #945784 05/17/09 11:57 PM
1
1984NCYota Offline OP
I have a 1984 4x4 22r and I'm changing it for a 86 22r 2wd. Does the oil pan need to changed for the 4x4? Also, is the clutch the same? The 86 2wd is a 5 speed.
Is there any other changes I need to do?
1984 X-cab 4x4, chevy one wire alternator, 22r, looking for mods
Re: swaping 86 22r 2wd into 84 4x4, does the oil pan need to changed [Re: 1984NCYota] #945785 05/18/09 01:54 AM
kewlynx Offline
Oilpan, sump tube; double check the dipstick and tube lengths, as it seems to me the 2wd one is about 1" shorter; been awhile.
Everything else will bolt up for ya. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Changing out the pilot bearing while you have it apart, yes?
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5889 MB (Peak: 0.6367 MB) Data Comp: Off Server Time: 2026-06-20 19:00:06 UTC
