air intake #945913 05/19/09 06:25 AM
toyT100 Offline OP
Does anyone know the specs on an air intake? I want to build my own with a piece by piece kit but am not sure what size piping I need and all those other important details...
Re: air intake [Re: toyT100] #945914 05/19/09 06:03 PM
G
Greg_Canada Offline
3.4? 2.75 i believe. Make sure you keep the pipe diameter the same as stock or it will mess up the MAF reading. (also make sure to keep the MAF the same distance from the engine)
89 4Runner
Re: air intake [Re: toyT100] #945915 05/19/09 07:23 PM
wsquaredodie Offline
Keep your bends to a minimum number and angle. Every bend drops flow rate like crazy. If you have a buddy who is an engineer, look up flow rate calcs and check it out. Smoother on the inside the better...
trafdlo
Re: air intake [Re: Greg_Canada] #945916 05/20/09 12:15 AM
toyT100 Offline OP
yes it is a 3.4, sry. I was worried this would be harder than advertised and its already looking to be that way...
Re: air intake [Re: toyT100] #945917 05/20/09 12:54 AM
G
gentouteg Offline
i've got an adapter that you can use with the stock intake tubes that'll allow you to use a k&n cone filter with it. it'll sit right in front of the map sensor. let me know if interested.
Re: air intake [Re: gentouteg] #945918 05/20/09 03:22 PM
G
Greg_Canada Offline
It has a MAF not an AFM, do you have the right adaptor?
Also, the stock airbox with a hole cut in the front makes more power than a cone filter. Airraid and Trueflow make intake tubes (dunno if they do for the t, check it out) and replacement filter, and they use the stock airbox.
89 4Runner
Re: air intake [Re: Greg_Canada] #945919 05/21/09 12:54 AM
G
gentouteg Offline
it is maf not map sensor. thanks for correcting that.
Re: air intake [Re: Greg_Canada] #945920 05/24/09 04:46 AM
toyT100 Offline OP
How bout this? I already have an K&N stock replacement filter, so will i get the same effect if I cut a hole in the upper side of the filter housing so the filter still does it's job? This would be instead of cutting a hole in the front of the housing and adding an adapter with a cone filter.
Re: air intake [Re: toyT100] #945921 05/24/09 06:40 AM
G
Greg_Canada Offline
Ok ok, search for the "deckplate mod".. i think gadget has it on his site www.gadgetonline.com as well as dyno graphs... check it out...
89 4Runner
Re: air intake [Re: Greg_Canada] #945922 05/24/09 11:04 PM
toyT100 Offline OP
haha yea i def typed before i though on this one!
I actually jus finished reading for bout 2 hrs strait about nothing but doing deckplate mods. Is adding a screen to the newly cut hole necessary or no?
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6344 MB (Peak: 0.7420 MB) Data Comp: Off Server Time: 2026-06-23 11:14:56 UTC
