thermo valve assm. ? #945926 05/19/09 12:13 PM
Torsion Offline OP
This weekend I replaced the valve cover gaskets on my '89 Raider with the 3.0 V6. When finished I noticed that my Thermo Valve assm. had broken off the vacuum connecters. It's located next to the thermostate housing. Two vacuum hoses run from it to the throttle body assm. My question is what is it for, and how will it effect operation with it being broken? Where can I get a replacement? Thanks.
89'Dodge Raider 3.0 V6, A/T
LSD, KYB equipped
Re: thermo valve assm. ? [Re: Torsion] #945927 05/19/09 03:28 PM
FrankR Offline
A check of the "search" function will show several posts describing thermo valve function.
The device is part of the EGR control system - in conjuction with the EGR solenoid valve and the EGR valve.
You should be able to get one from a dealer.
Frank
Re: thermo valve assm. ? [Re: Torsion] #945928 05/19/09 03:56 PM
LRJ4x4 Offline
There is a thermo valve and there is a thermo switch.
IIRC the Thermo valve has 5 vac lines and the thermo switch has two. I would have to look at the FSM but I sold it when I sold my 88.
<img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: thermo valve assm. ? [Re: LRJ4x4] #945929 05/19/09 07:39 PM
FrankR Offline
The thermo-porcupine used on the 2.6L and 2.0L is thankfully not used on the 3.0L.
I'm pretty sure he's talking about the thermo switched valve at the top/front of the water box - breakage is common on the 3.0L with heat and age.
Frank
Re: thermo valve assm. ? [Re: FrankR] #945930 05/20/09 03:59 PM
LRJ4x4 Offline
<img src="/forums/images/graemlins/lol.gif" alt="" /> good one Frank <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6070 MB (Peak: 0.6714 MB) Data Comp: Off Server Time: 2026-06-20 18:46:36 UTC
