Greasable Shackle / Hanger Pins #946134 05/20/09 09:24 PM
JEFF84 Offline OP
Who has Greasable Shackle and Hanger pins that I can purchase seperately?
I don't need the shackle itself only the pins and bushings.
I am only able to find the kits with the shackle which I don't need. <img src="/forums/images/graemlins/shiner.gif" alt="" />
Jeff
1984 EXT CAB PUP, Weber 32/36, LC Headers, DOA C270, Detroit (Rear), All-Pro Front.
Re: Greasable Shackle / Hanger Pins [Re: JEFF84] #946135 05/20/09 09:52 PM
4Crawler Offline
Re: Greasable Shackle / Hanger Pins [Re: 4Crawler] #946136 05/21/09 02:42 PM
JEFF84 Offline OP
Rog, thanks for the links, but I did not see any Front Spring Hanger Pins, you carry those ?
If not know were to purchase ?
Jeff
Re: Greasable Shackle / Hanger Pins [Re: JEFF84] #946137 05/21/09 05:03 PM
4Crawler Offline
Sorry don't have those, but if you can supply a set I can drill then for grease fittings as noted on the web page.
Re: Greasable Shackle / Hanger Pins [Re: 4Crawler] #946138 05/26/09 02:45 PM
JEFF84 Offline OP
I'll keep looking, if I find some that need drilling I will let you know !
Jeff
Re: Greasable Shackle / Hanger Pins [Re: JEFF84] #946139 05/26/09 03:43 PM
anthony1 Offline
Call these guys to see if they will sell the pins to you separately.
http://www.allprooffroad.com/9095suspension/9095springshackles
If you dont't like religeous holidays, go to work.Otherwise, let's call them what they are.
It's freedom OF religion not from.
95-4R,SAS,f/r locked,35MT/R 5spd, 4:1,5.29. my site
Re: Greasable Shackle / Hanger Pins [Re: anthony1] #946140 05/26/09 09:51 PM
4Crawler Offline
Looks like all AP has is the straight bolts as well. For the stock solid axle trucks, you have a unique sort of spring pin up front that fits into the hanger:
Another option is just to replace the stock front hanger with a new version drilled to accept a straight bolt:
http://www.4crawler.com/4x4/CheapTricks/CrossoverSteering/index.shtml#SpringHangerDrop
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.6219 MB (Peak: 0.7114 MB) Data Comp: Off Server Time: 2026-11-03 13:40:24 UTC
