Advice needed on exchanging 3.0 liter engines #946897 05/26/09 08:54 PM
87_Montero Offline OP
Will a 6G72, 3.0 liter Mitsubishi engine from a 2-wheel drive 1998 Montero Sport fit directly into a 1991 LWB Montero? Is this a direct fit and an easy swap? If you gurus tell me this is easy, then I've found an engine for the 1991 LWB (rod knock) I rescued from the junkyard a few weeks ago.
Bob
DDs:
Projects: 86 Ram50
Re: Advice needed on exchanging 3.0 liter engines [Re: 87_Montero] #946898 05/26/09 10:08 PM
FrankR Offline
The short answer is "No".
The long answer is that it can be made to work, but you'll need parts from the Gen1 engine - like the oil pan and some other top end parts, sensors, etc.
frank
Re: Advice needed on exchanging 3.0 liter engines [Re: FrankR] #946899 05/27/09 03:22 AM
justice Offline
You'll also have to figure out how to manage the engine as a 98 3.0 will be a 24 valve, disributerless setup. So your looking at swapping in the 98 ECM. Exhaust will need to be figured out as well.
Re: Advice needed on exchanging 3.0 liter engines [Re: justice] #946900 05/27/09 01:36 PM
Thanks, guys. It makes perfect sense . . . there would be a world of difference between a 1991 that has a carburetor, and a 1998 with electronic ignition. The 1998 also probably has fuel injection. The 1998 engine showed up on my radar via the 4x4wire. I suppose if I had seen it I would have recognized it would not be a direct transplant.
DDs:
Projects: 86 Ram50
Re: Advice needed on exchanging 3.0 liter engines [Re: 87_Montero] #946901 05/27/09 02:05 PM
FrankR Offline
The '91 is EFI - not carbureted, but there's still a world of difference in the rest of the engine.
Frank
Re: Advice needed on exchanging 3.0 liter engines [Re: FrankR] #946902 05/27/09 02:20 PM
Yes, the 1991 is EFI. Two things I've learned from the 4x4wire - humility, and the importance of holding onto my day job!
DDs:
Projects: 86 Ram50
Re: Advice needed on exchanging 3.0 liter engines [Re: 87_Montero] #946903 05/28/09 07:25 AM
Bernoulli Offline
If you go on with the swap, please document it. I'd like to do a 12V to 24V 3.0 swap.
89 3L V6 5spd SWB, Aisin Manual Hubs, 2 (suspension) seater Raider in Wheeler, OR
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.006s) Memory: 0.6140 MB (Peak: 0.6916 MB) Data Comp: Off Server Time: 2026-10-26 08:24:24 UTC
