lifts and alignments! #947028 05/27/09 10:27 PM
Iron Offline OP
Hi Guys!
Posted this in the Jeep section but it could be answered here as well!
I'm putting on a 1.75" suspension spacer lift and new shocks this weekend, but can't get the jeep to an alignment shop till the end of next week, will this cause any damage if I drive around without an alignment for a few days?
08' Jeep Wrangler
64' Plymouth Sport Fury 383
58' Triumph TR-3A
Re: lifts and alignments! [Re: Iron] #947029 05/27/09 10:55 PM
Hydra747 Offline
If u drive w/out alignment (and can drive) then I would certainly not worry about a thing.
But------
I think that the New Jeeps have a (traction sensor/stability ?????) Can't remember........... but it will throw a code if the steering is off and will NOT Let u accelerate <img src="/forums/images/graemlins/scared.gif" alt="" />
(something about those damn safety features)............
Better wait until u get both <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: lifts and alignments! [Re: Iron] #947030 05/27/09 11:26 PM
DennisThompson Offline
With your solid front axle you should not have a problem for that long, about all you may notice is your steering wheel won't be aligned. Thats what I noticed when I had my 98 TJ.
Dennis
Re: lifts and alignments! [Re: DennisThompson] #947031 05/28/09 03:02 AM
DEFBOY35 Offline
what dennis said!
with the solid axle, you shouldnt be messing with your camber or anything like that, i guess depending on how the steering is on it it shouldnt effect your toe at all either. might be as simple as adjusting the drop link on the steering to recenter the wheel.
2000 SPORTY, DEF BOY customs, mmm....lockers, mmm... gears, mmm... double transfer case, mmm... stroker
http://www.cardomain.com/ride/2377991
Re: lifts and alignments! [Re: DEFBOY35] #947032 05/28/09 03:22 AM
Hydra747 Offline
And what Hydra said <img src="/forums/images/graemlins/lol.gif" alt="" />
Be careful and do not get this guy to do DOUBLE DUTY (regarding work)! <img src="/forums/images/graemlins/shame.gif" alt="" />
PSS is a Bitxh when it does not allow ur vehicle to move <img src="/forums/images/graemlins/confused.gif" alt="" />
Please consider doing the lift----If ur gonna have to remove it again cause ur ride don't go. <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: lifts and alignments! [Re: Hydra747] #947033 05/28/09 01:41 PM
k120189 Offline
im sure there is a way to override that..or just pull the fuse
but yea your good to go it'll just make ur steering wheel crooked till u get an alignment
<a href="www.pittsfieldcustomsclub.com/sportage.html" target="_blank">98 sportage</a>: warn manual hubs,upyourkia spacers, 104 tj springs, 235/75/r15 BFG T/A KO, tracker rims, cone air filter, custom cat-back with a skunk2 muffler. gonna be a 2.3L
Re: lifts and alignments! [Re: k120189] #947034 05/29/09 12:29 AM
Iron Offline OP
There is an ESP on/off switch for when you take it off road, so worse case I turn the switch off for a day or so!
Thanks for the advise guys!
08' Jeep Wrangler
58' Triumph TR-3A
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6200 MB (Peak: 0.7111 MB) Data Comp: Off Server Time: 2026-06-07 04:25:39 UTC
