Engine Interchange
#947821
06/03/09 03:24 AM
I know that this topic has been beaten like a dead horse but,I have been doing alot of research on an engine to swap with my 6g72 SOHC.
I can get Diamante and 3000GT/Stealth engines rather easily, but there is the issues of it being an interference engine, the higher CR, block modification and parts changeover. Would swapping the Montero cams in help the torque curve? Has anyone done this swap, and has any input?
The Hyundai Sonata engine, from what I understand this is a drop in application with parts changeover?
I'm making the assumption that I wouldn't have to change the crankshafts out from any of the engine in order to work with my automatic?
I would really like it if I could get some carved in stone definitive answers before I go and spend the money to get a rebuildable core.
1993 Chevy Suburban 2500- Tow Rig
1991 Mitsubishi Montero LS LWB
SR Parts: Rear Axle Coils Trailing Arms Front Calipers and soon to have UCA's and idler arm. Dual Bouncies Air Lift Airbags Aisins 33x12.50x15 Custom Grooved TSL's
Body lift in the near future.
Re: Engine Interchange
[Re: ncdieselwrench]
#947822
06/03/09 11:40 AM
I used a 91 Stealth engine with the Stealth cams & it ran great, easily enough power down low & great on the top end. I know the Diamante is an interferance engine, but the Stealth was not.
Ed
Yankneck = Yankee ingenuity with Redneck stupidity. "How can I break it better?" 89 Raider 3.0 w/ 31's for now
#947823
06/03/09 01:44 PM
I know that this topic has been beaten like a dead horse but,I have been doing alot of research on an engine to swap with my 6g72 SOHC. Well, I suppose a few more licks on a dead horse won't hurt him much more that his present condition. <img src="/forums/images/graemlins/wink.gif" alt="" /> I would really like it if I could get some carved in stone definitive answers before I go and spend the money to get a rebuildable core. "Getting a rebuildable core" and "swapping to another engine" are two (2) distinctly different things and one has little bearing on the other. If what you want is a rebuildable block, then none of your concerns about compression ratio and valve interference matter. I'd use the Diamante SOHC 6G72 block. The crankshafts are interchangeable, as are the rods and heads. You will need new pistons, so use the Montero pistons, which will keep the compression ratio as OE and also provide the non-interference design. Swap the Montero cams into the Diamante heads and you now have a Montero engine. There are two (2) locating pins pressed into the Diamante block where the Montero A/C compressor is mounted. Grind those pins flush and everything else will work fine. You'll need to use the Montero brackets, oil pan, etc. to complete the job, so don't throw anything away until you've finished the job. If you need anymore stone carving, just hike up to the mountain top and hold the tablet high over your head..... Oh - grow a beard so I'll know who you are...... foolin' 'round with lightning gets a little tricky sometimes. <img src="/forums/images/graemlins/lol.gif" alt="" /> Frank
[Re: FrankR]
#947824
06/03/09 04:33 PM
Thanks, yeah I know about the difference but really what I want to do is a weekend job have both engines on stands, swap over the parts and drop it in. As far as using the diamante engine would it be better if I used the monty cams in the diamante heads, with the diamante pistons?
What about the other options available has anyone fooled with the Sonata setup?
#947825
06/03/09 06:12 PM
As far as using the diamante engine would it be better if I used the monty cams in the diamante heads, with the diamante pistons? Better for what? And why would you want to? Are you going to rebuild an engine from an open block (as your last post seemed to suggest) - or do you want a used long block that you can swap your Montero parts to without rebuilding the bottom end? The latter isn't rebuilding an engine at all. It's a hope and prayer method of engine repair. The Montero cams are advanced 7? more than the Diamante cams, so either use the Diamante cams with Diamante pistons or use Montero cams with Montero pistons. I cannot tell you what would happen if you used Montero cams with Diamante pistons, because I've never assembled that combination - you just might have an interference event on the first engine revolution. I also cannot tell you how your engine computer will deal with the Diamante cams and pistons, since your computer was programmed for the Montero CR and valve timing. It might work fine, it might not. You're on your own with the Sonata. Good luck, Frank
#947826
06/04/09 03:31 AM
In my research the early Stealh 12 valve had the 8.9 :1 compression and 164 cams , the same as the Monty 89 -91 and Sonata till 98. The later Steath GT3000 12 valve had the same as Diamante setup , 10:1 and ? like 137 cams. Hyundai and Kia buy all the discontinued engines from Mitsu , Sonata is the same engine ,,,probably without the Diamante strengthened block.
dave h. '89 Raider V6 5spd;Aisin Hubs;; Gen2 LS: frt. brakes, rear coils;U.C.arms;R.trailing arms;idler arm; rear LSD axle w.disc brakes ;2 battery system for Dog's fan; relocated ECU; custom bumpers;J.Baker receiver;Conferr roofrack; t-bar crank.
[Re: KrzyDav]
#947827
06/04/09 09:36 PM
can't simply state yes this works, no this doesnt, this can if you do this. have to exercise those fingures hu guys.
88 raider 4.3 about to be parted out.
87 raider 4cy on 32's
[Re: rolling_down_the_hill]
#947828
06/04/09 10:06 PM
99 Gen 2.5, fixing blown head gasket 89 SWB- 33's, ARB Front locker, SR rear locker/axle, SR F brakes, winch, WST Offroad Armor all Around, 2.85 Aussie T-case Gears (SOLD) Sold: (2) 95 SR's, 86 SWB, 90LWB, 91 LWB -Can Change a timing belt in my sleep..
[Re: KrzyDav]
#947829
06/05/09 12:32 AM
Also , along the same line ,,anybody looking to replace a DOHC 3.5 , you can get one out of 2005 ish : Kia Sorento, and Sedona ,,and Hyundai Sante Fe, and like a 05 Hyundai ? ?XGL? -350 ( not Sonata) .
[Re: justice]
#947830
06/05/09 01:46 AM
I think hes saying its all Catch 22 with swapping a motor out of a different vehicile in
--keRby
Ad Inexplorta
