torsion lift, wheres the bolt? #948000 06/04/09 12:21 AM
L
leefhead Offline OP
i took a look under my 91 rodeo (i got it today for free) and im not sure if i was trying to turn the right bolt, but it wasnt moving and i didnt want to put a cheater bar on it incase its the wrong one and it broke. where is it located on this vehicle? heres a few pics of my new rodeo smile
im planning on a SOA in the rear and torsion twist in the front, as well as a body lift. i should have no problem putting 33's on there right?
2003 Impala 3400 powered - DD
97 Swift 3400 powered - Race Car
91 Izusu Rodeo 4x4 3.1gm powered - Tow/Trail Rig
Re: torsion lift, wheres the bolt? [Re: leefhead] #948001 06/04/09 12:29 AM
mlclark Offline
Isuzu Moderator
Got salt, eh?
It's not surprising. The bolt faces downward and is at the very rearmost of the torsion bar. If you can't turn it, it is time to start soaking it in some sort of penetrating oil (Kroil, PB Blaster ect) for several days and then try again. From the looks of your body, I can promise you the adjusting bolt is rusted and it is going to take some work to get it freed up.
Good Luck,
Michael
Re: torsion lift, wheres the bolt? [Re: mlclark] #948002 06/04/09 01:06 AM
L
leefhead Offline OP
im not sure what the torsion bar looks like, and it probally doesnt help that i have the skid plate still on. maybe ill go take that off. do you have any pictures of what im looking for? every other 4x4 ive had was coils in the front, stick a coil spacer or a bigger coil in there and call it a day, lol. living in northern ontario, the salt really gives your car a kick in the nads. heres some under body pics. they do look worse than they really are. flaky but still solid, mostly...
Re: torsion lift, wheres the bolt? [Re: leefhead] #948003 06/04/09 01:54 AM
Jim_Paget Offline
The torsion bars are a round rod that runs from an attachment on the lower control arm to a bracket that is near the line between the two doors. The torsion bars are close to the frame rail and the adjuster bolt can be accessed without removing any skid pans. The adjuster bolt head is large, I believe 27 mm. The adjuster bolt is oriented vertically, so all you see is the head of the bolt. Depending on the model, the torsion bar is between 2 and 3 feet long.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: torsion lift, wheres the bolt? [Re: Jim_Paget] #948004 06/04/09 04:17 AM
L
leefhead Offline OP
thanks ill take another look tomorrow. unfortunately i dont have a socket that big but my buddy does ill just have to ask him for one. ill let you guys know how it goes. im guessing that it looks kinda like a sway bar, cause it looks like it has 2 sway bars on the front of the vehicle.
Re: torsion lift, wheres the bolt? [Re: leefhead] #948005 06/04/09 04:19 AM
Jim_Paget Offline
Doesn't really look like a sway bar. It is completely straight and runs from front toward the back.
Jim Paget
www.rrr4x4.com
Re: torsion lift, wheres the bolt? [Re: Jim_Paget] #948006 06/04/09 06:16 AM
mlclark Offline
Isuzu Moderator
It is dead center in your 2nd picture, above the skid plate. There is one on the other side that looks just like it. The torsion bar runs from there to the front lower a-arm. You really can't miss it.
Good luck
Re: torsion lift, wheres the bolt? [Re: mlclark] #948007 06/04/09 02:46 PM
BigSwede Offline
The torsion bars are the springs for the front suspension. The ride height adjustment bolts are 27mm as mentioned, and should be on a crossmember midway between the wheels on each side, near the frame rail.
Definitely start hitting the threads on that bolt with penetrating oil of some kind. That rust will make the bolt quite difficult to turn at first, you will likely need the leverage of a long breaker bar to get it started.
Serenity now!
Re: torsion lift, wheres the bolt? [Re: BigSwede] #948008 06/05/09 03:43 AM
L
leefhead Offline OP
thanks for all the help, i found the bolt, but i dont have a 27mm socket, ill ask my cousin to borrow his. i kept looking at the front end of the vehicle, turns out its in the middle, lol. again, thanks.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6311 MB (Peak: 0.7370 MB) Data Comp: Off Server Time: 2026-06-07 04:50:25 UTC
