Clutch pedal bracket SPRING question #948418 06/06/09 11:50 PM
bradf Offline OP
I too fixed my clutch pedal bracket based on the great info in this forum. However, I didn't notice ahead of time exactly how the spring connected. It seemed reasonably obvious, but doesn't seem to be working right. Things were fine for a couple of months, but now I'm having problems with the pedal not returning when I release it.
Could anyone take a pic of their clutch pedal, spring, and bracket so that I could see what it's supposed to look like?
Thanks!
Re: Clutch pedal bracket SPRING question [Re: bradf] #948419 06/07/09 04:44 AM
Bill_R Offline
I think that you have the spring connected properly, otherwise it would not have worked for several months prior to giving you this problem. I had a similar issue and it turned out to be the clutch master cylinder. The seals were bad. The best thing I did was get a Toyota master cylinder and replace it. I went through 2 of an off brand and they did not hold up.
Check for a part number here: http://www.toyodiy.com/
Then check an online Toy dealer or check your local to see what kind of a price they give you.
Bill Reid
'93 T100 SR5 4X4
'05 4Runner SR5 4x4 (wife's DD)
Re: Clutch pedal bracket SPRING question [Re: Bill_R] #948420 06/07/09 01:02 PM
E
eleet Offline
I agree with Bill, because when you open the screw to bleed the clutch, the pedal stays on the floor.
All I have to add is that if you are feeling cheap, the dealer has rebuild kits for both the master and slave, they are shown in the toyodiy diagrams.
Re: Clutch pedal bracket SPRING question [Re: eleet] #948421 06/08/09 06:34 PM
G
Greg_Canada Offline
CLutch master $59 from marlin crawler.. OEM parts http://marlincrawler.com/clutch/hydraulics/clutch-master-cylinder
89 4Runner
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6016 MB (Peak: 0.6575 MB) Data Comp: Off Server Time: 2026-06-21 19:01:29 UTC
