Radiator pressure cap 99 G.C. 4.7 v8
#948667
06/09/09 04:00 AM
Does anyone know if the stock 21p.s.i radiator cap can be replaced with a cap with about 14-18 p.s.i. the plastic o-ring type radiator seems to blow the o ring out every 45,000 Im on my 3rd one from the dealer 335.00 .does not have a blown head gasket nor does it over heat ,compression even through all cylinders.I think the problem is the high pressures the radiator is under,so I would like to drop the cap pressure,does anyone know if it will cause any problems.
Re: Radiator pressure cap 99 G.C. 4.7 v8
[Re: prospector]
#948668
06/09/09 06:22 AM
Try it! It should work. That little bit of pressure should only correspond to 5 or 6* I betcha it would work anywhere except maybe the Sahara.. Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: prospector]
#948669
06/12/09 12:48 AM
The later ones used an 18 psi cap. If you don't tow or drive in a hot climate, you might even try a 13 psi cap
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5918 MB (Peak: 0.6448 MB) Data Comp: Off Server Time: 2026-05-30 01:07:40 UTCValid HTML 5 and Valid CSS
