Spark plug wire keeps poping off of spark plug #948844 06/10/09 07:12 PM
8
89toy96 Offline OP
Has anybody had any trouble with the spark plug wire popping off of the spark plug on the 3.4L. Even when I push it down it will immediately pop back up. I used new wires. It only a problem when it pops completely out and then it becomes a 5 cylinder until i pop it back in.
Any thoughts on how to fix it
Thanks
Re: Spark plug wire keeps poping off of spark plug [Re: 89toy96] #948845 06/10/09 08:10 PM
Adam F Offline
Never had that problem.
What brand wires are you using? Sounds like they are too short.
I just installed NGK part number 4412 ($28 from rockauto.com) and they fit great.
97 4R, stock, daily driver
Re: Spark plug wire keeps poping off of spark plug [Re: Adam F] #948846 06/10/09 11:52 PM
CJMT100 Offline
Probably a bad wire maybe..
Re: Spark plug wire keeps poping off of spark plug [Re: Adam F] #948847 06/11/09 05:55 AM
8
89toy96 Offline OP
the wires are from the toyota dealership, i also thought that new wires would fix the problem. I am not sure about the spark plugs, haven't changed those in a while
Re: Spark plug wire keeps poping off of spark plug [Re: 89toy96] #948848 06/11/09 07:54 AM
BamZipPow Offline
It's possible that the spark plug top may be missing/broken. Since the wires are new and you checked the inside of the new wire fer possible problems, then the only thing left would be the plug. Like to see piccies when you find out what the deal is... <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Spark plug wire keeps poping off of spark plug [Re: 89toy96] #948849 06/11/09 02:14 PM
wsquaredodie Offline
A possibility - some plugs have the screw on tip. Could be that is inside your wire fitting and causing a poor fit???
trafdlo
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6118 MB (Peak: 0.6809 MB) Data Comp: Off Server Time: 2026-05-29 19:56:59 UTC
