Electrical no-no 1986 Pickup
#949064
06/12/09 12:14 AM
Next to the battery is this box. In it this is what I found. 2 pieces of cooper bent over on top of each other. They are hot with the key off. What is supposed to be there and what do you suggest I do to correct it. I am pretty sure this is not a good thing. ![[Linked Image]](http://farm4.static.flickr.com/3598/3622426428_fabb193d58_o.jpg)
Re: Electrical no-no 1986 Pickup
[Re: opusthe2nd]
#949065
06/12/09 01:40 AM
There should be an 80 amp circuit breaker there. It looks just like the red and green boxes to the left of it, but black.
85 Toyota SR5 Xtra Cab P/U
[Re: Toy Story]
#949066
06/12/09 02:25 AM
Ok, it doesnt look like I will be able to fix that so it will work. Is there another type breaker I can maybe put inline, etc?
[Re: opusthe2nd]
#949067
06/12/09 02:33 AM
Don't mess with a substitute. That 80 amp breaker is the B+ feed for the alternator.
$5 bux sez someone tried removing it in the past and didn't have a clue; busted it. You unbolt the fusebox from the fender, flip 'er over; it's bolted in. I take it either your fuse cover or the label on it is missing?
I'd say it blew at some point and the PO bent them over to make continuity for a temp fix. Did something similar for a couple teens awhile back to help them get to a parts store for a replacement.
Remember to disconnect your battery, eh?
[Re: kewlynx]
#949068
06/12/09 03:01 AM
I have the cover, no decal. Are you saying it is salvageable? All I need to get is the original breaker and it will be good?
I am assuming then that the copper parts are part of the old breaker.
[Re: opusthe2nd]
#949069
06/12/09 03:17 AM
Yep, like Kewlynx said, disconnect battery, unbolt the whole fusebox and on the bottom of it you'll see how those contacts are bolted in.
Remove those contacts and install a new circuit breaker.
[Re: Toy Story]
#949070
06/12/09 03:36 AM
[Re: opusthe2nd]
#949071
06/12/09 04:14 AM
I am assuming then that the copper parts are part of the old breaker. Yep, think of it as an oversized element wire in a fuse. 80 amps is quite a load by comparison.
[Re: kewlynx]
#949072
06/12/09 04:18 AM
[shakes head] Some people amaze me at their fixes.
[Re: opusthe2nd]
#949073
06/13/09 04:11 PM
Can someone give me a part number for this fuse? I cant seem to find one, nor can NAPA.
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6384 MB (Peak: 0.7413 MB) Data Comp: Off Server Time: 2026-10-24 12:56:43 UTCValid HTML 5 and Valid CSS
