22r Cylinder Head Install Tips? #949190 06/12/09 09:50 PM
dffrntwn Offline OP
Well my earlier thread was correct about the blown head gasket, the water jacket corroded too close to the number two cylinder and steam cleaned that piston real nice. But I got lucky and nothing was damaged or cracked.
So I am getting my head back from the shop today, and was wondering if there are some inside tips beyond the Haynes manual on reinstalling the head?
All is cleaned and spotless, ready to go.
Re: 22r Cylinder Head Install Tips? [Re: dffrntwn] #949191 06/12/09 10:25 PM
JD9996 Offline
NEW HEAD BOLTS !!!!!!!!!!!!!!!!!!
Re: 22r Cylinder Head Install Tips? [Re: JD9996] #949192 06/12/09 10:41 PM
Toy Story Offline
Make sure you get all of the oil/antifreeze and gunk out of the bottom of the head bolt holes in the block. If the bolts bottom out in that stuff, it can throw your torque readings off.
85 Toyota SR5 Xtra Cab P/U
Re: 22r Cylinder Head Install Tips? [Re: Toy Story] #949193 06/12/09 10:44 PM
Staceman Offline
What they said, at least make SURE there is no excess fluids in those holes before installing bolts. Torque to specs, in proper order. You got the head off, I'm sure you'll be fine getting her back on.
Re: 22r Cylinder Head Install Tips? [Re: JD9996] #949194 06/12/09 10:49 PM
dffrntwn Offline OP
I talked the machinist and the tech at the Toyota dealer, and they both said the head bolt should be fine to reuse as long as there was no corrosion or damage.
I guess this is a big debating point on the internet, bolt stretch and all.
So no gasket sealer, or anything special for the head gasket?
Re: 22r Cylinder Head Install Tips? [Re: dffrntwn] #949195 06/12/09 11:29 PM
Toy Story Offline
Without trying to stir that debate back up , I'll just say I've reused head bolts a few times and never had any issues.
Only apply sealant to the front corners. Like this:
Re: 22r Cylinder Head Install Tips? [Re: Toy Story] #949196 06/13/09 01:09 AM
CJM Offline
as above + double , and triple check the rear 1/2 moon + I always use a little extra sealant as well.
83 Trekker SR5
NEW Trekker forum
Re: 22r Cylinder Head Install Tips? [Re: CJM] #949197 06/13/09 02:51 AM
dffrntwn Offline OP
What about the intake manifold gasket, does that one require sealant?
Re: 22r Cylinder Head Install Tips? [Re: dffrntwn] #949198 06/13/09 03:09 AM
CJM Offline
nope .. just a clean surface OE gasket will have sufficant sealant already applied .
83 Trekker SR5
NEW Trekker forum
Re: 22r Cylinder Head Install Tips? [Re: CJM] #949199 06/13/09 04:23 PM
missouriman Offline
make sure when setting the head on you don't drop it onto the gasket.
to clean the threads, not every one has a tap that long!!
so I use a brass brush for cleaning a 20 ga shot gun, or what ever you have that fits well.
then brake cleaner and compressed air using a tube that will extend the blower to the bottom of the hole, (cover with a paper towel so you don't get a shot of dirty brake cleaner in the face.
LIGHTLY oil the bolt hole and threads of the bolt. tighten, drive 200 miles or so and re check bolts and lifters.
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6407 MB (Peak: 0.7593 MB) Data Comp: Off Server Time: 2026-10-22 07:38:45 UTC
