Re: 22r Cylinder Head Install Tips? [Re: dffrntwn] #949200 06/15/09 02:05 AM
kewlynx Offline
Yep, make sure the head bolts aren't stretched before reusing, chase the bolt holes in the block first as well. Make sure the intake/exhaust manifolds aren't warped; usually the latter needs a touchup.
Chase the manifold bolt holes as well; helicoil repair as needed.
If you have time, send off the injectors to be refurbished; www.rceng.com and witchhunter are recommende on this site.
Remove the butt splices on the fuel injector harness and solder them; this is a problem area with the older rigs. Again, do this if you don't need a quick turnaround.
**ubi apis- ibi salus**
Re: 22r Cylinder Head Install Tips? [Re: Staceman] #949201 06/26/09 11:36 PM
crazyhorse62 Offline
Where can I find torque specs for a 22r and tightening sequence?
Re: 22r Cylinder Head Install Tips? [Re: crazyhorse62] #949202 06/26/09 11:45 PM
Staceman Offline
FSM, Chiltons, or Haynes.
I don't have the ability to upload anything here from work this week.
Re: 22r Cylinder Head Install Tips? [Re: Staceman] #949203 06/27/09 12:04 AM
Toy Story Offline
Torque is 58 ft. lbs.
Arrow is the front.
85 Toyota SR5 Xtra Cab P/U
Re: 22r Cylinder Head Install Tips? [Re: Toy Story] #949204 06/27/09 01:47 AM
CJM Offline
58ft lbs , is correct but weak . I suggest 68-70ft lbs ..
I now do this consistantly to all my engines , and not had a headgasket problem since .
83 Trekker SR5
NEW Trekker forum
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6125 MB (Peak: 0.6930 MB) Data Comp: Off Server Time: 2026-06-21 01:29:07 UTC
