1993 SR Timing Question. #949519 06/16/09 03:59 AM
Troy24 Offline OP
I have a question regarding which terminal I ground before setting the timing. I am checking my timing after replacing the timeing belt and water pump.
There are two terminals side by side on my fire wall. One Black and one Tan. I am not positive but I think I used the tan colored terminal the last time I did this. I just want to double check before I ground something. The picture in the Haynes manual shows it near the wiper motor on the passenger side. But my wiper motor is on the drivers side and there are not terminals on that side only on the passenger side.
Any thoughts?
1993 Montero SR 205,936 miles. BF Goodrich A/T's Dual Bouncy Seats.
Re: 1993 SR Timing Question. [Re: Troy24] #949520 06/16/09 11:51 PM
While using the timing light on the marks, ground one of the wires and see if the timing moves close to factory spec. I think the other wire is just a fuel pump check terminal, and grounding it won't hurt. It wants 12v+ to check fuel pump run.
Re: 1993 SR Timing Question. [Re: fasteddy] #949521 06/17/09 12:13 AM
V
vr4 Offline
use a test light. no risk of damage this way.
probe 1 and if it lights while cranking thats the fuel pump terminal.
IIRC the connector you want for timing is the tan one.
87 Montero V6 SWB auto. dual bouncies
89 Montero V6 SWB 5 speed. dual bouncies
97 3000gt VR4 upgraded turbos, 10:1, E85
91 Stealth TT twin 18Gs, cams/heads, E85
03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" />
91 MR2 turbo
Re: 1993 SR Timing Question. [Re: vr4] #949522 06/17/09 03:41 AM
I think it's the brown, too...
Re: 1993 SR Timing Question. [Re: fasteddy] #949523 06/18/09 01:24 PM
Troy24 Offline OP
The tan terminal is the one. The other terminal had power. Thanks for the help.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6076 MB (Peak: 0.6723 MB) Data Comp: Off Server Time: 2026-06-20 21:42:53 UTC
