Fuel Gauge Problem #949524 06/16/09 04:03 AM
G
gerry_p Offline OP
My fuel gauge reads three quarters full whether the tank is empty or full. The jeep is a Willys but the tank is out of a mid 70's CJ. The gauge is brand new but the old one did the same thing. The Stewart Warner gauge has one wire going to the ignition, one to ground and one to the sending unit on the tank. The gauge connections are good. In addition the ground from the sending unit to ground is also good. Any ideas gents?
Gerry
Re: Fuel Gauge Problem [Re: gerry_p] #949525 06/16/09 05:41 AM
BigJim Offline
The sending gauges run on OHMs.. To many or too few OHMs and the thing don't work properly.
Someone here might know what you need for the gauge to work properly...I have forgot.
It is possible to ohm out the sending unit and see what you've got.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.5861 MB (Peak: 0.6339 MB) Data Comp: Off Server Time: 2026-11-03 13:38:00 UTC
