Page 2 of 3 1 2 3
Re: '86 4 cylinder to '94 SR V6 front brake swap questions [Re: Kevin C] #949640 06/25/09 09:47 PM
Thoma_s Offline
That's what i thought to.
The heat must have got to me.
Check it again tomorrow.
Thanks
1987 Pajero SWB 2.5TD LSD, 33" BFG MUD
Daily Driver
http://www.cardomain.com/ride/2327536/1
Re: '86 4 cylinder to '94 SR V6 front brake swap questions [Re: MartySoCal] #949641 06/25/09 10:46 PM
V
vr4 Offline
Thanks for the reply! One thing I forgot to ask is will the dual piston calipers clear 15x7 wheels?
my SR has 15x7s on it <img src="/forums/images/graemlins/frown.gif" alt="" />
87 Montero V6 SWB auto. dual bouncies
89 Montero V6 SWB 5 speed. dual bouncies
97 3000gt VR4 upgraded turbos, 10:1, E85
91 Stealth TT twin 18Gs, cams/heads, E85
03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" />
91 MR2 turbo
Re: '86 4 cylinder to '94 SR V6 front brake swap questions [Re: vr4] #949642 06/26/09 01:53 AM
Not sure about 15x7's but they clear my 15x8's w/ 4" of backspacing.
HTH <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: '86 4 cylinder to '94 SR V6 front brake swap questions [Re: off-roader] #949643 06/28/09 04:39 PM
MartySoCal Offline OP
I picked up a 1990 V6 Booster, Master cylinder, spacer for the firewall, vacuum supply hose with the internal check valve and the left front brake line (from the master to the frame)for $38 at the local junk jard. They seem to be in good shape! <img src="/forums/images/graemlins/smile.gif" alt="" />
One more question, will the '90 V6 front rotor dust shields fit with the dual piston calipers, or should I keep looking for the right ones?
Re: '86 4 cylinder to '94 SR V6 front brake swap questions [Re: MartySoCal] #949644 06/28/09 05:35 PM
Grasscat Offline
No they won't unless you modify them. If you can get the GenII's get them if not mod the one's you have, you will see what needs to be trim when you put the calipers on there. Also the little hard brake line need to be tweak a little or get the correct ones while finding the backing plates. Oh and get the little hard brake line clips that hold them to the calipers. I posted how to to all this with pictures sometime ago, but the search will only let me go back 200 post.
Michael j
TreadLightly! Trainer
Re: '86 4 cylinder to '94 SR V6 front brake swap questions [Re: Grasscat] #949645 06/28/09 05:53 PM
Thanks, <img src="/forums/images/graemlins/patriot.gif" alt="" /> I'll keep looking for the right ones!
Should I use the later lower/outer hoses, too?
Re: '86 4 cylinder to '94 SR V6 front brake swap questions [Re: MartySoCal] #949646 06/28/09 06:00 PM
Grasscat Offline
I used the ones I had as I had put news ones on sometime before the upgrade.
Michael j
Re: '86 4 cylinder to '94 SR V6 front brake swap questions [Re: Grasscat] #949647 06/28/09 06:31 PM
The listing on the hoses show the later ones are about 1-3/4" shorter than the earlier ones. (7" vs 8-3/4") Do you think they would be better to use, or would the original longer ones work fine?
Re: '86 4 cylinder to '94 SR V6 front brake swap questions [Re: MartySoCal] #949648 06/28/09 06:48 PM
Grasscat Offline
The original is what I used.
Michael j
Re: '86 4 cylinder to '94 SR V6 front brake swap questions [Re: MartySoCal] #949649 06/28/09 07:16 PM
Grasscat Offline
With the help of John I've found the write up I did on this swap.
Brake swap
Michael j
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6462 MB (Peak: 0.7706 MB) Data Comp: Off Server Time: 2026-06-20 22:17:49 UTC
