22r questions, HELP!!!!!!!!!!!!!!!!! Please!!!!!!!!!!!!! #949778 06/17/09 06:18 PM
dirtdobberoffroad Offline OP
I am building a Samurai and putting a 22r 5speed tranny and t-case out of a 84 4 runner I was wondering if the 22r (carbed) will run with out the computer that is in the passenger kick panel? Much appreciated. <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/confused.gif" alt="" />
Building a Toyzuki!
Re: 22r questions, HELP!!!!!!!!!!!!!!!!! Please!!!!!!!!!!!!! [Re: dirtdobberoffroad] #949779 06/19/09 03:45 AM
Scerb Offline
yes it will.
Re: 22r questions, HELP!!!!!!!!!!!!!!!!! Please!!!!!!!!!!!!! [Re: Scerb] #949780 06/19/09 10:56 PM
does it affect the performance of the engine?
Building a Toyzuki!
Re: 22r questions, HELP!!!!!!!!!!!!!!!!! Please!!!!!!!!!!!!! [Re: dirtdobberoffroad] #949781 06/20/09 02:09 AM
CJM Offline
emissions computer ? or ECM ...
here in Canada .. we dont have the computer on a carbed engine .. and all of our trucks are still running .. well only the best ones !!! smile So I would have to say yes .
83 Trekker SR5
NEW Trekker forum
Re: 22r questions, HELP!!!!!!!!!!!!!!!!! Please!!!!!!!!!!!!! [Re: dirtdobberoffroad] #949782 06/22/09 07:23 PM
SALMONHEAD Offline
Just stick a Weber on it and get power to the ignition.
84 4RUNNER,22R,HEDMAN,WEBER 32/36,Davis Unified Ignition,33" BFG
Re: 22r questions, HELP!!!!!!!!!!!!!!!!! Please!!!!!!!!!!!!! [Re: SALMONHEAD] #949783 06/24/09 05:39 PM
Alright that is exactly what I wanted to hear thanks any more suggestions?
Building a Toyzuki!
Re: 22r questions, HELP!!!!!!!!!!!!!!!!! Please!!!!!!!!!!!!! [Re: dirtdobberoffroad] #949784 06/24/09 07:36 PM
SALMONHEAD Offline
If you like things simple and want to spend the money, the Davis Unified Ignition (DUI) replaces the coil, igniter and distributor with a 2 wire hook up (one to 12v and one to the tach)and a single vacuum line to the carb (or none if you choose the mechanical advance model. Hedman headers are available without the O2 port as well.
Re: 22r questions, HELP!!!!!!!!!!!!!!!!! Please!!!!!!!!!!!!! [Re: SALMONHEAD] #949785 06/25/09 07:18 PM
how much power loss/gain could I expect with LP?
Building a Toyzuki!
Re: 22r questions, HELP!!!!!!!!!!!!!!!!! Please!!!!!!!!!!!!! [Re: dirtdobberoffroad] #949786 07/03/09 06:09 PM
What I am thinking is stock pistons on LP(propane), then puting a turbo off of a irigation motor/power unit, it will add about 40hp not much but I think it would be more than high compression pistons on only LP, I would be afraid of puting the HC pistons with the turbo.
Building a Toyzuki!
Re: 22r questions, HELP!!!!!!!!!!!!!!!!! Please!!!!!!!!!!!!! [Re: dirtdobberoffroad] #949787 07/03/09 06:36 PM
G
Greg_Canada Offline
Aww dont be that ghetto. Do the turbo right and it will last forever. The steedspeed manifolds ($500) are very nice, pick up a T3/T4 turbo (4-500) and you've got reliable power.
89 4Runner
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6353 MB (Peak: 0.7417 MB) Data Comp: Off Server Time: 2026-06-07 05:51:36 UTC
