1998 Montero ATF Fluid #949968 06/18/09 12:21 PM
CJ3B Offline OP
Hello Gents:
Did a quick search, but it seems that most of the threads related to this question are for previous years trucks (older than 1998), and I cannot find the truck's owner's manual (used to be my wife's truck, and my guess is that she tossed it our in order to acquire space for her stuff in the glove compartment...).
I'd like to know what is the AT fluid I'd have to use to replace the one I have in the tranny (1998 Montero). Is the oil change recommendable? Wouldn't it affect the performance? I ask, since I haven't had to touch (repair) the tranny in 12 years I've had her.
Thanks for the feedback.
Jorge
1998 Mitsubishi Montero
1965 Willys CJ3B
Re: 1998 Montero ATF Fluid [Re: CJ3B] #949969 06/19/09 10:22 AM
CJ3B Offline OP
Thanks all. Contacted Mitsubishi.
1965 Willys CJ3B
Re: 1998 Montero ATF Fluid [Re: CJ3B] #949970 06/19/09 02:47 PM
Sorry for the late reply. I answered you on the other forum but in case you didn't see my reply I have a 96SR and my owners manual suggest ATF Dexron II (or a newer compatible ATF).
HTH. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 1998 Montero ATF Fluid [Re: off-roader] #949971 06/19/09 02:51 PM
Mad_Scientist Offline
I believe Mitsu changed the tranny in '97 (hence the 1" higher body mounts to accommodate it). I only use the Mitsu diamond SPII or III from the dealer. There have been a few discussion about this in the past so using the search function might be useful to you <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 1998 Montero ATF Fluid [Re: Mad_Scientist] #949972 06/19/09 03:03 PM
Scottie2113 Offline
yes, I agree, use diamond fluid only, you can't go wrong. diamond fluid plus mitsu transmission = bulletproof
97 Montero SR w/Mitsu Adj Shocks & Rear Diff Lock ARB Front Diff Lock 4.9 Ring/Pinion 3.15 transfer box 43:1 crawl ratio 2" suspen lift 2" body lift 2" Gas Tank Lift 35x12.5 MTRs 15x10 Wheels Rock Sliderz ARB front bumper w/12k winch Custom rear bumper
Re: 1998 Montero ATF Fluid [Re: Mad_Scientist] #949973 06/19/09 05:44 PM
CJ3B Offline OP
Used the search, but is a pain to use, and no post indicated anything regarding 1998-specific.
Wouldn't want to pour the old stuff (and risk tranny damage)when a newer conccoction is out there.
Thanks again,
Jorge
1965 Willys CJ3B
Re: 1998 Montero ATF Fluid [Re: CJ3B] #949974 06/19/09 11:04 PM
Yes, the search is a pain. And I don't ever remember a post answering that question, anyway. I'd go with the dealer juice, too. Probably worth the premium over dexron3. ATF is just full of detergents, since the tight tolerances of the valve body are very sensitive to gum. These detergents get used up over time. Change the fluid, clean the filter, and count on many, many more happy miles. Resist any recommendation to flush it. Too risky.
Re: 1998 Montero ATF Fluid [Re: fasteddy] #949975 06/20/09 04:15 PM
MartySoCal Offline
Chrysler replaced the Diamond SP III fluid with ATF +4 about a year ago, for their versions of Mitsubishi vehicles. If you can't get the factory stuff ATF +4 is a bit easier to find at parts stores.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6272 MB (Peak: 0.7060 MB) Data Comp: Off Server Time: 2026-05-29 22:19:38 UTC
