Ready to scream #950546 06/22/09 10:38 PM
G
graeaglecrawler Offline OP
I can not get the rear drum off, which way do you turn the adjuster?
'91 montero a/t cranked t-bars 31x10.5x15 212k
'90 toyota extra cab 320k v6 5 speed 31's 4x4
'99 expedition 17" alloys v-8 207k 4x4
'88 BMW 325iX 247k AWD
'59 Willys Jeep Koenig PTO winch and hardtop 28k
Re: Ready to scream [Re: graeaglecrawler] #950547 06/22/09 10:53 PM
justice Offline
Use the holes. Insert bolts and turn.
Re: Ready to scream [Re: justice] #950548 06/22/09 11:09 PM
G
Both of those stripped!
Re: Ready to scream [Re: graeaglecrawler] #950549 06/22/09 11:20 PM
zarktheshark Offline
I used a 1 lb hammer and banged around the edges of the drum. Since I was not going to re-use the drum, i didn't really care if it broke or not (which it did not), but i don't know if any damage was done in the process. It did take quite awhile (5-10min), but it finally vibrated enough to break loos from the studs and the center part of the axel.
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab
'15 Subaru XV
'03 BMW i325
Re: Ready to scream [Re: zarktheshark] #950550 06/23/09 12:22 AM
Just to be sure, you have the e-brake off, right. I've done that one before...
Adjusters work opposite on oppo wheels...
Re: Ready to scream [Re: graeaglecrawler] #950551 06/23/09 04:16 AM
ghostraider Offline
how did that happen?
<img src="/forums/images/graemlins/scared.gif" alt="" />
Re: Ready to scream [Re: ghostraider] #950552 06/23/09 06:49 AM
LandRaider Offline
It's likely that your drum is stuck on the face of the axle flange, and not the shoes.
Make sure you backed the adjuster all the way in, and the axle will spin freely, then install all the lugnuts so you don't accidentally hit the studs with the hammer, and them smack the poopoo out of the drum face with a fairly light hammer. Not a huge 10 lb sledge. You want speed, not force. After a few times, you should hear it start to make a different sound, and it should come off.
This works 99% of the time.
Re: Ready to scream [Re: LandRaider] #950553 06/23/09 10:42 PM
PartyTruck Offline
You sound like a pirate in a tea party. <img src="/forums/images/graemlins/lol.gif" alt="" /> yarrrr.
1987 SWB Pajero 2.5 TDI on 31" rubber waiting for a hip replacement and bigger shoes
Re: Ready to scream [Re: PartyTruck] #950554 06/23/09 11:04 PM
I like to get a little prying force on the back rim of the drum to put it under strain, then smack the poopoo out of the face. Once it starts, it's easy if the adjuster is backed off right.
Re: Ready to scream [Re: LandRaider] #950555 06/24/09 12:28 AM
1
1986powerram50 Offline
poopoo
poopoo
<img src="/forums/images/graemlins/lol.gif" alt="" />fftopic: I think LandRaider started a new thing, saying "poopoo" what a trendsetter. Really surpised his 4.3 and solid axles w/ air lockers hasnt caught on great big <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
--keRby
Ad Inexplorta
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.009s) Memory: 0.6380 MB (Peak: 0.7414 MB) Data Comp: Off Server Time: 2026-10-21 17:31:03 UTC
