oil pan gasket #950602 06/23/09 03:44 AM
saylracer Offline OP
Can I get some advice on how to install the oil pan (gasket) so that it doesn't leak? I have removed/replaced my pan gasket on my 84 pickup about four times in the last 3 weeks and it still leaks. I have used of gasket,and sealer; gasket only; etc. Any help would be appreciated.
Re: oil pan gasket [Re: saylracer] #950603 06/23/09 04:15 AM
missouriman Offline
sounds like the bolts have been over tightened leaving dimples rather then a flat mounting surface.
make sure the pan is flat.
Re: oil pan gasket [Re: missouriman] #950604 06/23/09 04:18 AM
Adam F Offline
Use a ball peen hammer to flatten the dimples. Put the mounting surface on the edge of a table and hammer them flat.
97 4R, stock, daily driver
Re: oil pan gasket [Re: saylracer] #950605 06/23/09 04:25 AM
OOP'S Offline
Take a small block of steel that will fit in the lip on the outside of the pan and a small hammer and tap all of the bolt holes flat from the top of the pan. Throw the gasket away (they did not come with one from the factory) and go to Toyota and buy a tube of black FIPG and use that. The tube will run you 25-30 dollars but it is good stuff. Run about an 1/8 inch bead on all the mateing surfaces on the pan. Bolt up but do not overtighten the bolts, FSM call for 9 ft lbs.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: oil pan gasket [Re: saylracer] #950606 06/23/09 07:32 PM
SALMONHEAD Offline
Actually the 1984 did come with a gasket (a nice one that was rubber impregnated). The best advice is to assemble it with the sealant and only tighten enough for all surfaces to make contact. Then WAIT, as in do it Friday night and don't fill it or fire it until Sunday. Then after the sealant is totally cured you can snug it down and fill it.
Good Luck.
84 4RUNNER,22R,HEDMAN,WEBER 32/36,Davis Unified Ignition,33" BFG
Re: oil pan gasket [Re: SALMONHEAD] #950607 06/23/09 09:42 PM
Staceman Offline
And, make sure the pan and block surfaces are clean before applying the goop.
Re: oil pan gasket [Re: Staceman] #950608 06/23/09 10:02 PM
Toy Story Offline
Are you sure it's the pan that is leaking? Front or rear main seal and oil pressure sender leaks can look a lot like oil pan leaks.
85 Toyota SR5 Xtra Cab P/U
Re: oil pan gasket [Re: Toy Story] #950609 06/23/09 10:25 PM
Staceman Offline
oooh
good point!
Re: oil pan gasket [Re: Staceman] #950610 06/24/09 02:42 AM
CJM Offline
never one to be with the "croud" ..... after so many replacements I would have to ask myself "are you sure it's the O/Pan gasket leaking ?"
could it be maybe the o/pump o ring ? or rear seal ? or something else ?
83 Trekker SR5
NEW Trekker forum
Re: oil pan gasket [Re: CJM] #950611 06/24/09 03:07 AM
Yeah its the pan...I will try again armed with new info. Wish me luck
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6316 MB (Peak: 0.7347 MB) Data Comp: Off Server Time: 2026-11-03 20:54:14 UTC
