Binding in 4wd #950782 06/24/09 02:47 PM
homerdog Offline OP
When I put my Sportage in 4wd and take off it sounds like something is binding up. I'll get a loud banging noise every few seconds and when I hit the gas. I've checked and regreased both front hubs, checked and greased the front drive shaft. What else should I check?
2001 Sportage, TJ 106's, Everet spacers and bumpstops, Bilstein shocks on the rear, cone filter, Crager wheels, 235-75-15 Goodyear tires. Custom front winch bumper by Dave Scott. Currently DOA, but it is a work in progress.
2011 Kia Forte EX
Re: Binding in 4wd [Re: homerdog] #950783 06/24/09 06:15 PM
fokion Offline
was that from the first time you bought it???
does it bind on strait line?
Doyou make the tests on tarmac??
Re: Binding in 4wd [Re: fokion] #950784 06/24/09 08:00 PM
homerdog Offline OP
No, it was fine last year and I first noticed it at the beginning of winter with the first big snowfall. It does it on pavement, gravel, wet grass, pretty much all the time. At higher speeds it still does it but it's not as noticeable, just feels like you're hitting cracks in the pavement, at slow speed it's really noticeable, you can feel and hear it. I'm pretty sure it started after I put the front lift on, don't know if that would have anything to do with it though. There was someone on here a while ago that sounded like she was having the same symptoms with her Sportage, pretty sure she didn't have a lift on it though. And yes, it does it in a straight line.
2011 Kia Forte EX
Re: Binding in 4wd [Re: homerdog] #950785 06/25/09 12:11 AM
jaboo5322 Offline
On mine the cv shaft seals went, and the noise was the hubs kicking in and out. Mostly while on slippery ground though. And really loud thumping. But i could tell right away when it went from 2 to 4 wheel drive.
2001 Sportage, 4" RSG lift, Cragers W/31 10.5 Micky Claws, Warn Manual Hubs, 16 gallon Pro Street Fuel Cell, Custom Snorkel, K&N Filter.
1989 Dodge W250.
Re: Binding in 4wd [Re: jaboo5322] #950786 06/25/09 10:10 AM
fokion Offline
Sounds like the front bearings are gone...
Specialy the the small needle one..
Re: Binding in 4wd [Re: fokion] #950787 06/25/09 01:47 PM
homerdog Offline OP
Is this the one?
2011 Kia Forte EX
Re: Binding in 4wd [Re: homerdog] #950788 06/25/09 02:24 PM
fokion Offline
From around there for sure!!!
If i remenber right its visible from the back side were the rubber gasket it of the half shaft
Re: Binding in 4wd [Re: fokion] #950789 06/25/09 07:42 PM
homerdog Offline OP
They are a part of the halfshaft?
2011 Kia Forte EX
Re: Binding in 4wd [Re: homerdog] #950790 06/25/09 09:24 PM
fokion Offline
The halfsaft goes throu them, they support thiw end of the shaft
Re: Binding in 4wd [Re: fokion] #950791 06/26/09 01:38 AM
homerdog Offline OP
ok thanks, looks like I've got another project to add to my list
2011 Kia Forte EX
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6320 MB (Peak: 0.7384 MB) Data Comp: Off Server Time: 2026-10-24 13:10:06 UTC
