valve stem seals 87 4cy.
#950904
06/25/09 02:29 PM
started tearing it apart and have a ? or 2.can i just remove the valve cover? i dont want to screw my timing all up in the process. is there a trick to it or is it as simple as it seams to be. and i did search the arcives but didnt find anything as far as details explaining what they did.
88 raider 4.3 about to be parted out.
87 raider 4cy on 32's
Re: valve stem seals 87 4cy.
[Re: rolling_down_the_hill]
#950905
06/25/09 07:24 PM
You remove the rocker cover and the rocker arm assembly. Use a valve spring compressor to pull the springs and you can get at the seals. I recommend going to Napa and getting the spark plug adapter to run compressed air into the cylinder to keep the valve in place while you change the seals. I just did the procedure last week on my V6 and used to have a 2.6L. The procedure is similar with the difference being how much $hit you have to remove to get to the valve cover. HTH
73 -Jon KJ6GVM As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter Grampa's Trooper 1974 FJ40 1987 FJ60
[Re: Oyaji_Jon]
#950906
06/26/09 02:59 AM
ty, i got the tools required already. and jay gave me a book tonight telling me the same thing to.
#950907
06/26/09 06:53 PM
Just a tip, or two. The cylinder will leak compressed air as you change seals. With the summer and the humidity the compressor air will have a lot of water in it. If you have a water trap keep an eye on it as it will fill up quickly. I'd advise a complete oil change before starting the engine to remove any water in the pan oil. Use a small screw driver tip magnet to remove and re-install keepers.
[Re: pcc]
#950908
06/26/09 07:20 PM
i am, got new oil n filter waiting, and after about 300 miles im changing again for insurance. and ty for the tips.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6051 MB (Peak: 0.6697 MB) Data Comp: Off Server Time: 2026-06-10 01:47:05 UTCValid HTML 5 and Valid CSS
