97 TJ Sahara - What is this part? Steering/Suspension #951129 06/26/09 04:28 PM
CAskier Offline OP
A part of my steering or suspension is broken ( see picture ). Looks like some kind of stabilizer. The bushings look to be shot. What is it and how do I fix it? The part is hanging down on both sides.
Re: 97 TJ Sahara - What is this part? Steering/Suspension [Re: CAskier] #951130 06/26/09 05:56 PM
MartySoCal Offline
It's your anti-sway bar link. If you have a lift kit you will need to get extended links or the stock parts will keep on breaking.
Re: 97 TJ Sahara - What is this part? Steering/Suspension [Re: MartySoCal] #951131 06/26/09 06:02 PM
CAskier Offline OP
no lift kit, everything is standard. Can I just buy the bushings or do I have to replace the whole link? Is installation as simple as it looks? Just pop the old ones off and put the new ones on? Quadratec difficulty ranking is "experts only"... why?
Re: 97 TJ Sahara - What is this part? Steering/Suspension [Re: CAskier] #951132 06/26/09 09:53 PM
BobRowe Offline
First off, if one side is broken, and the broken pieces are that far away from each other, the other side is likely broken, too.
Yes, you purchase new anti-sway bar links and just replace them. I don't agree with the Quadratec rating. The grunt effort to replace them may be up there, but the technical knowledge required is minimal. Look at any technical manual for your vehicle (OEM or aftermarket), and the explanation of the job should be relatively simple.
Re: 97 TJ Sahara - What is this part? Steering/Suspension [Re: BobRowe] #951133 06/27/09 12:47 AM
reepersteve Offline
With this topic is here. I wanted to replace my factory sway bar with something like a Terraflex kit. (bar and arms) I have the disconnects from my RC lift. I was wondering if one is supposed to preload the bar. I saw some articles in one of the known mags. about this. I don't think it would be necessary? Any answers.
The drivers side of the bar is bent, making it hard to disengage.
01' TJ Wangler, 6" Ruff Country X Series, 35" x 12.5" Mickey Thompsons On 15 x 10" rims w/ simi Bead Lock, Matching Warn Bumpers, 9500xi Warn Wench, Tom Woods Drive Shaft And SYE, And A K+N Cool Air Intake. Still Improving
Re: 97 TJ Sahara - What is this part? Steering/Suspension [Re: reepersteve] #951134 06/27/09 02:37 AM
MartySoCal Offline
The only reason I could see to preload it would be to offset a side to side lean condition, ie. add length to bring a side that is sagging a bit back into line.
Re: 97 TJ Sahara - What is this part? Steering/Suspension [Re: MartySoCal] #951135 06/27/09 03:20 PM
reepersteve Offline
gotcha...
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6163 MB (Peak: 0.6945 MB) Data Comp: Off Server Time: 2026-06-10 07:16:19 UTC
