Page 16 of 17 1 2 14 15 16 17
Re: Post Pictures Of Your Kia [Re: 2002_Sporty] #951374 08/03/11 12:12 PM
Dryver Offline
I like the center of spare backup light. <img src="/forums/images/graemlins/kewl.gif" alt="" />
I've been considering doing the same thing for some time now, but with a brake light instead. On the 2-door, the spare tire is actually mounted on the tailgate, which opens to the side. There is a big plastic riser for the third brakelight so that it sits over top of the spare. I had to put spacers under the riser to make it clear the bigger spare, and it would be nice to eliminate it and regain a little more view out the back.
01 Convertible; Electric Fan; 3" Up Your Kia lift spacers; Tj 104's; 31x10.5x15's on Centerlines; Rear LSD.
GONE, all I have left are a few spare parts and the wheels.
Re: Post Pictures Of Your Kia [Re: Dryver] #951375 08/03/11 12:51 PM
2002_Sporty Offline
The third brake light centered in the bore of the spare wheel is a test run. I used a DOT approved 4" round tractor light wedged between the wheel and the spare mounting bracket. I wired the light to a used 7 prong trailer hitch. Light only works when I plug it into the hitch.
I wanted to go the other route and have spot lights for back up lights in the 4" square reflector housing. But after extensive use of the Sporty in the snow. I opted against that. without mud flaps; the reflector area gets covered in snow. I'm still debating on how that area will turn out.
I use 5 dollar resistors in all my tail lights so they blink before I stop. Warning those behind to slow down on the Ice before they slide into me in the winter.
I really want better backup lighting though. But haven't decided yet.
Lights on the roof rack would seem like an easy option, but when it's snowing hard, all you see is snow fall. So I wanted to mount the backuplight lower to illuminate the trail and not the falling snow.
2002 4dr Kia Sportage 4X4
Tires:235/75/15, Wheels: Black 15x8 Steel ProComp 2.5" B.S., Hubs:Warn Manual, Lift:3" UPYOURKIA, Trailer Hitch, Cargo Rack, Clinometer.
Re: Post Pictures Of Your Kia [Re: 2002_Sporty] #951376 08/04/11 10:05 PM
timd75 Offline
[Linked Image][Linked Image][Linked Image][Linked Image][Linked Image][Linked Image][Linked Image][Linked Image][Linked Image]
99 Sportage 2Dr, 1.5" body lift, 30x9.50 Cooper M/T's, high lift, CB, custom bumpers, Warn manual hubs, Tom Tom GPS, snorkel.
99 Jeep Cherokee 3" lift, 31" mud terrains
Re: Post Pictures Of Your Kia [Re: timd75] #951377 08/05/11 05:54 AM
Sportege_Panicmech Offline
Tape on intake looks bad (just bein honest no offense), but it's purpose is worth it as long as it holds out the water. I like how you used your trunk access and took off the hatch to use it for more room. We should scheme up a swivel hinge for the O.E. panel so you can close it and reopen it. wouldn't be hard at all =)
Re: Post Pictures Of Your Kia [Re: Sportege_Panicmech] #951378 08/05/11 07:43 AM
4
4runnernomore Offline
TIMD 75,
Can you please modify you post so the photos are underneath eah other instead of across.
Thanks
97 Sporty, snorkel, K&N filter,chipped, ext forks, 40mm Dob Springs, KYB struts, 35mm Jeep TJ Springs, RAV 4 OME shocks, Kaiser Locker 5.38 R&P's, 1&3/8 body lift, 245/75 R16 D674's Sports steering wheel, bullbar, extractors & 2 1/4 exhaust engineered.
Re: Post Pictures Of Your Kia [Re: 4runnernomore] #951379 08/05/11 01:05 PM
2002_Sporty Offline
Sweet looking ride. Thanks for the Pics.
I Second that notion on the floor.
Fix the Pics please. Hard to view in this manner.
Re: Post Pictures Of Your Kia [Re: 2002_Sporty] #951380 08/06/11 02:55 PM
timd75 Offline
I don't know why the pics look different for some. When I view them, they are normal. I thought about hinging the floor, but with the way the carpet is and the recess in the floor, it opens and closes the same as it would if it had hinges. The old cover showed how weak it was when I put a keg of beer in there, so I made one out of plywood. Way better.The floor spot holds a lot of stuff. I removed the factory jack since I have a hi-lift and steel bumpers. It hold an air compressor, jumper cables, shackles, tire plug kit, lug wrench, ratcheting straps, bungee cords, and the base for the hi-lift and still has room. The duct tape on the intake does look bad, but was one of those temporary fixes that worked too well, so I haven't given it much thought. I can say, I know for sure the snorkel works!
Re: Post Pictures Of Your Kia [Re: timd75] #951381 08/09/11 01:10 AM
hambodian Offline
Put on some Firestone Destination M/T 31x10.5. Broke the front left hub, dented the rear right door on tree, and broke the rear roof rack bar. Still made it through a lot of stuff in rear drive only. Wish I had limited slip or something in both front and rear.
96 Sportage EX. Automatic. Sold and sadly missed
4" UpYourKia lift
89 Ram 50 4x4. 4D56T swap in progress
30x9.5x15 Pirelli Scorpion M/T on Toyota steel wheels
06 VW Touareg V10 TDI.
Re: Post Pictures Of Your Kia [Re: hambodian] #951382 08/20/11 05:26 AM
DUDE!! Lovin that sportage Hambodian! Lights and rack on top with the lift and wheels does it well. And rep'n Tacoma, nice! I'm over in Idaho. Seeing more and more sportages around in the NW on here. Thinking next summer maybe we'll have enough for a decent trail meet. Although, I've never done one. And I've been mostly a pavement pounder, would love to get some mild trailin under my belt. I typically go for the deep snow when we get it. Easier to clean up than mud. and doesn't fill the chassis/ wire harnesses like mud does. Maybe a winter meet haha! <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: Post Pictures Of Your Kia [Re: k120189] #1101534 06/16/16 09:53 PM
530sportage Offline
Just finished the rear shock relocation and homemade coil retainers. I'm running 31x10.50x15 kenda klever mudder's at 15psi out back and 20psi up front. The shock relocation easily doubled my flex. What do you fellas think?
PHP: 7.4.33 Page Time: 0.009s Queries: 17 (0.007s) Memory: 0.6502 MB (Peak: 0.7777 MB) Data Comp: Off Server Time: 2026-05-27 20:57:33 UTC
