Junk in the trunk, & better gas mileage #951873 07/01/09 10:06 PM
Seattlegti Offline OP
Not just for Jeeps.
I've noticed my mileage slipping down to low teens and tried several tricks to bring it back up to the 20 it had when I bought it..
Easy, soft driving went up from 14 to 15.5, eh not much fun.
45 psi in tires, well up to 16 mpg but ride sucks and MTs howl.
Back down to 30 psi.
Last trick seems to be working. Im up to 18 in the city and WOO HOO got 22 mpg on a trip to the coast.
Removed the following;
Folding back seat -100 lbs
3 piece fiberglass top -200 lbs
Spare tire & mount -100 lbs
Carpet and hi-Lift -30 lbs
Trunk box full of recovery chain, snow chains,salt and 2x 4 ton come-alongs -200 lbs
So as you'd expect. 0 to 60 is much faster, braking distance is much shorter, less roll in corners and overall a real pleasure to drive again.
Granted much of this is stuff I'll need at some point.
But the daily commute to work is a bit more fun and I'm getting a nice forhead and left arm burn.
Plan to remove the lead doors next and see what another 300 lbs less feels like. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Think I gained about an inch and a half of lift in the process. Have to climb in rather than hop in.
Re: Junk in the trunk, & better gas mileage [Re: Seattlegti] #951874 07/02/09 12:07 AM
justice Offline
Yea, I'm beginning to see, the more junk I add to my 89 the slower it gets..Heavier back seat out of 95, Custom bumpers winch, sliders, roofrack, thick skid, CO2 tank, action packer full of tools..It starts to add up...
Re: Junk in the trunk, & better gas mileage [Re: justice] #951875 07/02/09 01:27 AM
Grasscat Offline
I need to do that also, maybe even put quick disconnects on the winch.
Hijack
Hey justice,
How did you install the seat?
Michael j
TreadLightly! Trainer
Re: Junk in the trunk, & better gas mileage [Re: Grasscat] #951876 07/02/09 01:33 AM
Jim_Paget Offline
I used to do a lot of competitive sailboat racing, in fairly big (> 40') boats. One of the local gurus used to tell everyone that if they wanted a cheap way to go faster, just clean out everything that you didn't really need. It was amazing how much difference it made even in boats that carried 10-12 crew.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: Junk in the trunk, & better gas mileage [Re: Grasscat] #951877 07/06/09 09:32 PM
justice Offline
Hijack
Hey justice,
Its the Jump seats bolted to the slightly modified Gen1 rear tubling bench seat frame.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6086 MB (Peak: 0.6743 MB) Data Comp: Off Server Time: 2026-05-29 16:17:05 UTC
