Where's the coolant drain plug #952522 07/07/09 03:45 AM
garym Offline OP
It's been 3 yrs since I changed it and thought I wrote myself a note,but NO. Anyway, does anyone know where the
&%#$@# block drain is on the 3.4?
Thanks
1997 T-100 4X4 Xcab,Warn Hubs
02 Camry LE
2008 Yaris
Re: Where's the coolant drain plug [Re: garym] #952523 07/07/09 06:30 PM
BamZipPow Offline
It should be located just below the exhaust manifolds... <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: Where's the coolant drain plug [Re: BamZipPow] #952524 07/07/09 09:27 PM
CJMT100 Offline
iirc your right, DONT DO IT WHILE THE TRUCKS HOT! I learned the hard way lol.
Re: Where's the coolant drain plug [Re: CJMT100] #952525 07/08/09 01:31 AM
garym Offline OP
Thanks. Driver or passenger side? I swear I looked everywhere but didn't see it. Finally just pulled the lower hose. One manual I have says it's by the timing belt so I pulled that cover off too and nothing.
02 Camry LE
2008 Yaris
Re: Where's the coolant drain plug [Re: garym] #952526 07/08/09 09:30 PM
ErikB Offline
Toyota Moderator
Its a 14mm brass plug right near the motor mount. I think its on the passenger's side.
http://home.4x4wire.com/erik
Re: Where's the coolant drain plug [Re: ErikB] #952527 07/08/09 09:46 PM
Dandeman Offline
Toyota Moderator
Yep on the right side and actually quite easy to reach if you go in through the right wheel well, behind the splash flap, and use a socket on a long extension... at least on a 4Runner.
I do it with the front of the vehicle higher than the rear and the engine drains dry.. The 3.4 is also the easiest to fill of any vehicle I've had to not have a hassle with trapped air and burping coolant out..
Re: Where's the coolant drain plug [Re: Dandeman] #952528 07/09/09 12:37 AM
CJMT100 Offline
When I did flush last summer I didnt bother with the plug itself. I drained the lower hose and petcock on the rad. Then refilled with water 3x and ran/drained. Works for me and I been doing it a long time.
Re: Where's the coolant drain plug [Re: CJMT100] #952529 07/09/09 05:22 AM
kewlynx Offline
Remember the newer T100's and the Tacos have the same mills, so check the FSM sticky in the Taco section, page 4 in the post:
http://www.ncttora.com/fsm/2003/Repair_Manual/03tacoma/co2rzfe3/cool/repl.pdf
**ubi apis- ibi salus**
Re: Where's the coolant drain plug [Re: kewlynx] #952530 07/11/09 06:46 PM
garym Offline OP
Thanks for all the replies. Finally found it by feel and an inspection mirror. Maybe it's because I don't have any lift but I can't see it through the side flap.
Kewlynx: Thanks for the URL. That is the same pict. as in my FSM. It shows that plug up front, if I read it correctly. It must be for the 3.0 and they never updated the pict. in the 3.4 FSM. Confusing. <img src="/forums/images/graemlins/confused.gif" alt="" />
02 Camry LE
2008 Yaris
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6261 MB (Peak: 0.7286 MB) Data Comp: Off Server Time: 2026-05-29 19:58:02 UTC
