Where's the coolant drain plug
#952522
07/07/09 03:45 AM
It's been 3 yrs since I changed it and thought I wrote myself a note,but NO. Anyway, does anyone know where the &%#$@# block drain is on the 3.4?
Thanks
1997 T-100 4X4 Xcab,Warn Hubs 02 Camry LE 2008 Yaris
Re: Where's the coolant drain plug
[Re: garym]
#952523
07/07/09 06:30 PM
It should be located just below the exhaust manifolds... <img src="/forums/images/graemlins/wink.gif" alt="" />
[Re: BamZipPow]
#952524
07/07/09 09:27 PM
It should be located just below the exhaust manifolds... <img src="/forums/images/graemlins/wink.gif" alt="" /> iirc your right, DONT DO IT WHILE THE TRUCKS HOT! I learned the hard way lol.
[Re: CJMT100]
#952525
07/08/09 01:31 AM
Thanks. Driver or passenger side? I swear I looked everywhere but didn't see it. Finally just pulled the lower hose. One manual I have says it's by the timing belt so I pulled that cover off too and nothing.
[Re: garym]
#952526
07/08/09 09:30 PM
Toyota Moderator
Its a 14mm brass plug right near the motor mount. I think its on the passenger's side.
[Re: ErikB]
#952527
07/08/09 09:46 PM
Toyota Moderator
Its a 14mm brass plug right near the motor mount. I think its on the passenger's side. Yep on the right side and actually quite easy to reach if you go in through the right wheel well, behind the splash flap, and use a socket on a long extension... at least on a 4Runner. I do it with the front of the vehicle higher than the rear and the engine drains dry.. The 3.4 is also the easiest to fill of any vehicle I've had to not have a hassle with trapped air and burping coolant out..
2000 4Runner,V6,Auto,31's, Sliders, Skids, On-Board Air, Air Shocks Related Interests: Welding, Ham Radio, Road Tripping (Blue Highways), High End Video/Audio Systems
[Re: Dandeman]
#952528
07/09/09 12:37 AM
When I did flush last summer I didnt bother with the plug itself. I drained the lower hose and petcock on the rad. Then refilled with water 3x and ran/drained. Works for me and I been doing it a long time.
[Re: kewlynx]
#952530
07/11/09 06:46 PM
Thanks for all the replies. Finally found it by feel and an inspection mirror. Maybe it's because I don't have any lift but I can't see it through the side flap.
Kewlynx: Thanks for the URL. That is the same pict. as in my FSM. It shows that plug up front, if I read it correctly. It must be for the 3.0 and they never updated the pict. in the 3.4 FSM. Confusing. <img src="/forums/images/graemlins/confused.gif" alt="" />
