Help please! Rear Axles #953069 07/09/09 08:54 PM
shadowrider Offline OP
I am pulling the rear end of my 1998 Kia Sportage because the ring and Pinion gears have gone bad. How do I pull the axles to get the stump out?
Re: Help please! Rear Axles [Re: shadowrider] #953070 07/10/09 12:49 AM
V
victwisted Offline
If I were you Ied start by taking out the hole rearend take the tires off and put it up on a bench, pull off your drum breaks and that should get you to the axles
99' sportage,4"lift RSG,31" M/T Baja MTZ on DC1 rims,custom 1 3/4" body lift, one dog,one cooler,one heavy foot,maps, and the will to wheel my kia with the rest of the offroad world
Re: Help please! Rear Axles [Re: victwisted] #953071 07/10/09 04:48 AM
bombardj1 Offline
use the www.kiatechinfo.com it should help
2001 5sp. K&N stock filter 215/70/15
If your check engine light is on at least you know the light still works
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.008s) Memory: 0.5905 MB (Peak: 0.6434 MB) Data Comp: Off Server Time: 2026-10-27 03:30:37 UTC
