Page 1 of 4 1 2 3 4
3 " body lift on auto tranny sportage #953491 07/13/09 12:41 AM
5
5jackz Offline OP
Hi, Just wondering if anybody has installed the 3" lift on a sportage with an automatic tranny? I'm wondering what sorts of problems I might run into. Thanx.
2000 with Eibach Suspension lift,Warn man. hubs,K&N air filter,15x8 mags with 31's, 3.75" body lift.
Re: 3 " body lift on auto tranny sportage [Re: 5jackz] #953492 07/14/09 03:22 AM
jays2001 Offline
the fornt brake lines need to be bent alittle and the shift linkage and the transfer shifter u will need to cut the floor or bend stick and ac watch closely pw steering res relocated aaaaa auto shifter just lenghten the bar a little ooooo make sure u disconnect from under car bfore starting because it jams pretty tight into park after lift truuuust me
in a hurry if u need more help pm me ill have more time tuesday mine was 3.75 body lift
01 w/31 in. mtr,winch,elec.fan ,4 in.suspension lift and 4in. body lift,front and rear hitch. NOT ENOUGH POWER so V8 and solid axles coming soon.2013
Re: 3 " body lift on auto tranny sportage [Re: jays2001] #953493 07/14/09 05:52 AM
5
5jackz Offline OP
Thanx
Re: 3 " body lift on auto tranny sportage [Re: 5jackz] #953494 07/15/09 01:08 AM
jays2001 Offline
also the steering will come into contact with the small brake line box below the master cylinder on the fender i just bent the fender out problem solved. i can take pics just let me know
Re: 3 " body lift on auto tranny sportage [Re: jays2001] #953495 07/16/09 05:38 AM
5
5jackz Offline OP
Does anything have to be done with the hand brake?
Re: 3 " body lift on auto tranny sportage [Re: 5jackz] #953496 07/17/09 02:29 AM
jays2001 Offline
nope
Re: 3 " body lift on auto tranny sportage [Re: jays2001] #953497 07/23/09 06:07 AM
Dave Scott Offline
you can also use an extra rear brake hose to lengthen the front brake hoses on some years, i know it works on 95's... that way, no bending, and plenty of room for droop...
Re: 3 " body lift on auto tranny sportage [Re: Dave Scott] #953498 07/23/09 06:26 AM
5
5jackz Offline OP
Thanx again
Re: 3 " body lift on auto tranny sportage [Re: 5jackz] #953499 07/25/09 11:52 PM
Hydra747 Offline
This has been a real serious interest to me regarding Sporty and body lifts..........
Is anyone going to post Pictures anytime soon??????
Just wondering....
Re: 3 " body lift on auto tranny sportage [Re: Hydra747] #953500 07/26/09 01:09 AM
jays2001 Offline
what pics you looking for of what needs done or ????
Page 1 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6395 MB (Peak: 0.7464 MB) Data Comp: Off Server Time: 2026-05-26 04:56:44 UTC
