97 4 rnr tranny, no revers, stays in 1st #953689 07/14/09 03:54 AM
skered53 Offline OP
she make a ticking noise in park, no longer has reverse and will not shift out of 1st gear. Is there anything I can try or just call the x-mission peeps ?
This is the rig that had the radiator core failure last august which cuased the cooant and x-miss fluid exchange. I replaced the rad and flushed the tranny, seemed to fix the problem. I might have put 6K miles on it since.
Any ideas ?? is it dead or should I pull the pan and look for ??? I pulled the pan with the prior incident, there wasn't any chunks of stuff in it. drained a quart today, still no chunks.
Re: 97 4 rnr tranny, no revers, stays in 1st [Re: skered53] #953690 07/14/09 05:18 AM
G
Greg_Canada Offline
how much did you flush the tranny? my dads did the same thing and we kept flushing till it was clean. I think his mechanic used a power flusher, then again after a week.
89 4Runner
Re: 97 4 rnr tranny, no revers, stays in 1st [Re: skered53] #953691 07/14/09 05:33 AM
Adam F Offline
What does the fluid look like?
97 4R, stock, daily driver
Re: 97 4 rnr tranny, no revers, stays in 1st [Re: Adam F] #953692 07/14/09 06:02 AM
skered53 Offline OP
back in August I flushed it it about 8 gallons of fluid, just poured it in real slow until it came out ruby red with no bubbles. Then I changed a gallon every 1000 miles for the next 3 gallons, the stuff is still ruby red with no bubbles.
right now the fluid looks new, on my fingers and on a rag. the quart I drained into a cottage cheese container has a slight darker tint, ie I cant see the bottom on a 6 inch container, it does not smell burnt.
Re: 97 4 rnr tranny, no revers, stays in 1st [Re: skered53] #953693 07/14/09 02:02 PM
G
Greg_Canada Offline
Might have to go to some pro's for that. eek.
89 4Runner
Re: 97 4 rnr tranny, no revers, stays in 1st [Re: Greg_Canada] #953694 07/14/09 05:19 PM
Adam F Offline
I agree.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6109 MB (Peak: 0.6804 MB) Data Comp: Off Server Time: 2026-06-17 12:02:05 UTC
