200k maintenance #953695 07/14/09 04:10 AM
Glock24 Offline OP
My truck is nearing the 200k mark, so I took it for a t-bel change, and also looked at some other things that needed attention. Here's what I did:
- Replaced timing belts, tensioners and oil seals.
- Replaced fuel filter.
- Oil and filter change.
- Replaced transmission mount, was not completely blown, but would be soon.
- Replaced trailing arm bushings, which were blown, see pic below.
- Replaced temp sensor, which was reporting wrong temps.
- Straightened the cross member on which the transmission sits, as it was bent, pushing the transmission like 1cm upwards, also was rubbing one of the torsion bars.
- Also, not so long ago I changed the transfer, transmission and differential oils. Alternator and radiator are less than 6 months old.
The trailing arms bushing were very, very tight. The guy that operates the hydraulic press had a hard time taking them out, but took him much more effort to put in the new ones. He said the day before he changed the bushings of a Nissan Patrol, and those were piece of cake, but these made him sweat it!
Here are some (very bad) pictures of the blown bushings:
Still pending:
- Check/adjust valve clearance.
- Check front suspension/steering components for play.
- Tire balancing and steering alignment.
- Check rear brakes, adjustment of proportioning valve.
'98 Galloper II Exceed 2.5TDI LWB 5sp Manual 5.29 Diffs
Re: 200k maintenance [Re: Glock24] #953696 07/14/09 06:18 AM
redbull Offline
Cool. Feels good to get that stuff done, doesn't it? I just got my front end done, but I'm sure I'll need a Bunch of suspension bushings soon too. Where did you buy yours?
Re: 200k maintenance [Re: redbull] #953697 07/14/09 07:33 AM
torquemonster Offline
I rebuilt my whole front end last November and I felt so relieved to get it done, the only thing I didn't do was upper ball-joints and pitman arm. The next project on the pajero is sway bar bushings and trailing arm bushings!
Re: 200k maintenance [Re: torquemonster] #953698 07/14/09 08:04 PM
redbull Offline
I had the upper and lower ball joints, tie rods, pitman arm and idler all changed out. It's in getting the alignment now.
Let me know if/when you find the bushings please! I'll need to order those.
Re: 200k maintenance [Re: redbull] #953699 07/15/09 05:55 AM
Glock24 Offline OP
Yes it feels good to get things done. I bought the bushings at a local parts dealer (I'm in Nicaragua, not US or Canada). I think they are the same for any Gen I or II Pajero/montero, so you should not have problems finding it.
Sway bar bushings replacement is quick, unless you have smashed or bent the nut/bolt like I did <img src="/forums/images/graemlins/notooth.gif" alt="" />
Last time I changed them I had to replace the bolts too.
BTW, anyone know the proper way to adjust the proportioning valve? I need to give the rear end a little more braking power.
Re: 200k maintenance [Re: Glock24] #953700 07/25/09 08:19 PM
Glock24 Offline OP
Last weekend I went to a beach ~150km from where I live, 20km of which are dirt road. When I was on my way on the dirt road, the left front shock absorber support pin broke. I could still drive, but very slowly.
On my way back I changed the pin and bushing, an also did the following:
- Checked front suspension/steering components for play. The front wheel bearings had a little play, had to be tightened. The idler arm was a bit loose, so it was re-tightened too.
- One of the rear brakes cylinder was leaking, changed the seals and adjusted the brake shoes. Braking has significantly improved.
- After this I took her for a wheel alignment.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6115 MB (Peak: 0.6992 MB) Data Comp: Off Server Time: 2026-07-09 15:41:39 UTC
