brake pedal extremely hard #953796 07/14/09 11:59 PM
celticta2s Offline OP
As I was driving to lunch today. I went to stop at a light, and the pedal started normal and then got really hard. The pedal needs to be pressed extremely hard to get the truck to stop. I changed out my rotors about a month ago, but have not had problems until today. Could it need to be bleed? It's almost like the booster went out or ...?
I am still at work and I don't think I want to drive it the 30 miles home on the highway.
Any help would be much appreciated!
1994 X-Cab V6 Auto 4X4 (3VZ-E/A340H)
Re: brake pedal extremely hard [Re: celticta2s] #953797 07/15/09 12:08 AM
Staceman Offline
Make sure there is no air leak with the hose between the brake booste and intake manifold. Start there I'd guess. Possible that the diaphram blew out in the booster. Unlikely, but not impossible.
Re: brake pedal extremely hard [Re: Staceman] #953798 07/15/09 12:21 AM
The hose is fine. It was the third or fourth time I had to stop that this happened. Any other suggestions on what to check?
Re: brake pedal extremely hard [Re: celticta2s] #953799 07/15/09 12:51 AM
Snowtoy Offline
Bleeding isn't likely the problem. Air in the lines would tend to give you a soft pedal, or one that fades. A failing Master cylinder would tend to do the same
I know when stalling on a hill climb off road, the brake pedal in both rigs is stiff, so my first guess would be you are not getting assistance from the brake booster. Check the vacuum lines, one may have come loose, is collapsing, or cracked, then check to see if the vacuum pressure from the engine is, and whether or not the brake booster has a leak.
Re: brake pedal extremely hard [Re: Snowtoy] #953800 07/15/09 04:24 PM
I reluctantly drove it home last night...
Anyways, I checked the vacuum lines, and all appeared to be fine. They were still pliable, with good connections. I pulled the line off at the booster with the engine running, and there was, what seemed to be, plenty of suction.
How go you check for a booster leak on these. There are no visual signs of a fluid leak, and I don't hear a air (vacuum) leak.
Re: brake pedal extremely hard [Re: celticta2s] #953801 07/15/09 04:29 PM
Ralph Offline
Is there missing brake fluid
Look for signs of brake fluid inside the booster, or the vacume line to it.
Ralph
1991 Toyota 4x4 Standard Cab Pickup.
engnbldr cam and head.
Doug Thorley Headers
Home Made Cat Backs
30x9.5x15 BF Goodrich All-Terrain M/T KM2
Re: brake pedal extremely hard [Re: Ralph] #953802 07/15/09 04:49 PM
The brake fluid is unchanged. The level is right at the Max Level line, and I don't see any leaking at any of the fittings.
Re: brake pedal extremely hard [Re: celticta2s] #953803 07/15/09 04:55 PM
Adam F Offline
A hard pedal means the booster is not doing its job.
Check the one way valve on the booster (the plastic piece in between the line and the booster) You should be able to blow in it one way but not the other.
Testing your booster with a vacuum gauge
http://www.type2.com/library/brakes/vacboo.htm
97 4R, stock, daily driver
Re: brake pedal extremely hard [Re: Adam F] #953804 07/15/09 05:13 PM
Thanks for the link.
I will give it a try tonight when I get home.
Re: brake pedal extremely hard [Re: celticta2s] #953805 07/15/09 05:32 PM
suba Offline
Have you recently added any fluid to the system?
86 4runner, pro comp AAL, Kayline Soft top, 31's but all stock
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6368 MB (Peak: 0.7599 MB) Data Comp: Off Server Time: 2026-11-02 08:27:45 UTC
