Toyota oil filters Japan or Malaysia #953807 07/15/09 12:04 AM
Hackattack Offline OP
I went to the Toyota stealership for an oil filter for my Tacoma. They had a special buy 3 filters for $3.99 ea. I bought 3 and went home to change my oil. When I took my oil filter off I noticed it said Denso made in Japan. When I opened up the new filter it said Denso Made in Malaysia and was made differently than the Japan filter. Has anyone noticed this or did I get the cheap bargin filter.
Toyota T100 best truck Toyota ever built "Its so good the frame does not rust in half"
Re: Toyota oil filters Japan or Malaysia [Re: Hackattack] #953808 07/15/09 07:25 AM
humanoid Offline
The ones you buy from your local dealer will most likely be made in Malaysia, while the one that came from the factory will be from Japan. The Malaysian ones are built to factory spec. Carson Toyota sells the ones made in Japan, but they are very pricey.
Re: Toyota oil filters Japan or Malaysia [Re: humanoid] #953809 07/15/09 11:38 AM
kewlynx Offline
Cut if you still have your old filter, cut it open. It seems to me the media should be a ballon shaped media for the filter material; most other filters are concentric in their shape.
The reason I suggest this is that I remember reading an article several years ago about Toyota changing their filter design.
If you're up for cutting one of the Malaysia filters too, post a couple pictures, if able.
Got me curious now!!
**ubi apis- ibi salus**
Re: Toyota oil filters Japan or Malaysia [Re: kewlynx] #953810 07/15/09 04:58 PM
humanoid Offline
Found the link. Carson Toyota sells the filter for about $14 each.
http://www.newtoyotaparts.com/product/?id=2217
Re: Toyota oil filters Japan or Malaysia [Re: humanoid] #953811 07/16/09 03:42 PM
Mark in AZ Offline
Toyota Moderator
<img src="/forums/images/graemlins/kewl.gif" alt="" /> could use them for the 4Runner and the Taco. Thanks!
Exploring in a T4R Ltd V8
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.6054 MB (Peak: 0.6697 MB) Data Comp: Off Server Time: 2026-07-16 03:41:24 UTC
