Re: Mitsu 9" and Ford 9" Compatibility [Re: LandRaider] #953983 07/16/09 10:52 PM
justice Offline
Pipe Dream... <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Mitsu 9" and Ford 9" Compatibility [Re: LandRaider] #953984 07/17/09 12:20 AM
desteurm Offline
Just because the splines are the same doesn't mean the axles will fit. There's quite a bit to consider.
Axle diameter, Spline, length.
Bearings shouldn't matter because he's swapping the WHOLE ford 3rd member into the Mitsubishi housing.
Does the ford 3rd member put the center into the centerline of the axletubes?
Is the bolt pattern around the edge the same? Sealing surface around the edge?
Does it even fit in there at all?
I'm only considering the differential carrier not the whole thrid member for my aplication. Both Ford and Mitsu with 31 spline should have the same dimetral pitch. I wish there was more 94+ monteros in the wreckers so I could try <img src="/forums/images/graemlins/cheers.gif" alt="" />
Yes it is a pipe dream to find a cheap rear locker <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: Mitsu 9" and Ford 9" Compatibility [Re: desteurm] #953985 07/17/09 12:29 AM
Ford 31 spline, 33.5mm 1.32"
Mitsu 31 spline 35.5mm 1.40"
Re: Mitsu 9" and Ford 9" Compatibility [Re: OldColt] #953986 07/17/09 05:15 AM
Another note, ford splines are machined and the mitsu ones are forged. I doubt they would mate together like they should, it would either be really tight or a little sloppy. It is an interesting swap and it would be cool for gearing options but the mitsu axles are much stronger and an improvement over the ford 9" wich they were designed after.
Re: Mitsu 9" and Ford 9" Compatibility [Re: TOASTY] #953987 07/17/09 08:29 PM
desteurm Offline
I guess the tooth thickness of each spline could be different. In general, automotive spline shape is the same across the board.
By forged I think you mean rolled...it's hard to forge all around an axle shaft. Rolled splines are stronger no doubt.
Re: Mitsu 9" and Ford 9" Compatibility [Re: LandRaider] #953988 08/16/09 02:59 AM
1
1986powerram50 Offline OP
Check out the thread on outerlimits, he posted up
--keRby
Ad Inexplorta
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6214 MB (Peak: 0.7085 MB) Data Comp: Off Server Time: 2026-05-29 14:44:49 UTC
